idling problems
Old Apr 29, 2003 | 02:56 PM
bmann03's Avatar
idling problems
hey as you guys might know i just bought a 2nd generation RX-7. It is having an idling problem. A friend of mine said it could possibly be the apex seal. I have no clue what that is. first of all i was wandering if anyone has experienced the same problem. if so how did you go about fixing it. and what are the symptoms of a blown apex seal. how much would it cost to get that fixed. could i possibly find some kind of gasket rebuid kit and how much that would cost. the car is kind of old and i sure none of the gaskets have been replace. or would i be better off just buying a new engine.
Old Apr 29, 2003 | 03:00 PM
SureShot's Avatar
Seduced by the DARK SIDE
A compression check will tell the story on the internals.
Here is the deal on idleing.
The rotary engine has so little torque at idle that half of the stuff on top of the motor is for idle speed control. The BAC is the main controller of idle speed but it needs help with suddenly switching loads like headlights or AC or heater fan on high. These other accessories have signals to the ECU to open various vacuum bleed solenoids to help out. That is why the idle tune up is so complex.
I have a mirror copy of the manuals linked in my sig.
Old Apr 29, 2003 | 03:10 PM
jgathome's Avatar
Im having a similar problem with my 87 Turbo II.
When I first turn it on if I ever stop giving it gas it will shut off. After about 5 minutes of driving the problem goes away, but it makes driving a bit of work at first.
I left the car at home and took my old Accord to school, Ill look at it again this weekend, hopefully its nothing big
Old Apr 29, 2003 | 03:19 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
First thig check your TPS with a multimeter and set it if neccessary. Clean the BAC and use the idle screw to adjust the idle if really nessecary. Start replacing your vaccuum lines since they are probably old and broke/leaking.
Old Apr 29, 2003 | 03:27 PM
bmann03's Avatar
thank you for your help you guys but you keep using abbreviations for everything. what exactly is a BAC and a TPS.
Old Apr 29, 2003 | 03:34 PM
1987RX7guy's Avatar
TPS(throttle Position Sensor)
BAC(Bypass Air Contol valve)
For more info gor here: https://www.rx7club.com/forum/showth...hreadid=181219
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
