Pulled both engines today
Old Apr 28, 2003 | 08:12 PM
Sir Coolness
Yup, 9 am we started work on the cars... Pulled the engine out of the base, and it took longer than we expected , but 6 hours later the entire engine, transmission, and harnesses were all out..
Pushed that car out of the way and rolled the GXL up onto the lift and basically went to down on it. Took us 45 minutes to get the AC and PS pulled off the engine and put to the side and then the engine and tranny were also out..
Took a little break so we could kind of regroup on a game plan.. The engine mounts from the base model broke apart when we took them out, so we ended up reusing the mounts from the GXL, and then we came across another problem. The GXL has cruise control, and it's hooked into the upper intake and runs off a vaccum but on the base the vac line itself is plugged but there isn't a mounting spot for it like there is on the GXL upper.
So for right now we're not going to worry about getting the cruise control working right, our main concern is to make sure that the car start up and run correctly once we get everything all hooked back up and liquified..
I didn't take a single picture as really my hands were covered literally in oil, grease, and coolant all day and I wouldn't of been able to touch the camera with those hands so basically there are no images from the install.. All in all the difficulty level of the install isn't too bad..
Working with a guy who has been pulling engines for a while, we kind of used the first engine pull as our learning step, and then the 2nd engine was gravy.
So hopefully the GXL will be road ready sometime in the next few days
Old Apr 28, 2003 | 09:02 PM
marcus219's Avatar
FC Mobsta
So this is like an update on the car or.....
cool stuff!
and how did you chage your avatar text w/out 1000 posts?
Old Apr 28, 2003 | 09:09 PM
Sir Coolness
cool stuff!
Yes this is an update, basically I'm bringing the GXL back to life... So the first step was to get a heartbeat pulsing.. Then it was to fix up the exterior, then the interior and then it's good to roll
Old Apr 28, 2003 | 09:17 PM
silverrotor's Avatar
I'm pretty sure It's after 200 posts.
Old Apr 28, 2003 | 09:21 PM
marcus219's Avatar
FC Mobsta
After 200 posts...I'm almost positive you can't change the writing below your name till after 1000..I said avatar text though, wrong word I guess..not the avatar, the writing he has above it.
It says Sir coolness...
Old Apr 28, 2003 | 09:22 PM
Rx7Nub's Avatar
TII 4 SALE!
And he has only 177... and I can't change mine yet either... =\
Old Apr 28, 2003 | 09:23 PM
Sir Coolness
I'm just a badass
Old Apr 28, 2003 | 09:24 PM
Rx7Nub's Avatar
TII 4 SALE!
Wait, your thinking of Avatar, they are talking about Avatar TEXT, the stuf above the avatar.
Old Apr 28, 2003 | 09:25 PM
marcus219's Avatar
FC Mobsta
IC...cool.
Old Apr 28, 2003 | 09:33 PM
marcus219's Avatar
FC Mobsta
I said avatar text..oh well..I got it now..
Old Apr 28, 2003 | 09:59 PM
I thought the same thing when I saw pd day's. He was below 1000 and had MQD, or something like that. He Is also a member from '01, like brian s. I dunno.
Old Apr 29, 2003 | 10:55 AM
Scrapiron7's Avatar
STi Boxer power!
Originally posted by Brian S
I'm just a badass
LOL
Old Apr 29, 2003 | 10:16 PM
Sir Coolness
Originally posted by bricke
LOL
Damn skippy... You know it's true
Th0m4s
Feb 26, 2019 02:04 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
maikelc
Aug 24, 2015 11:04 AM
