I just went premix MY CAR WON"T START!!!!
Old Apr 28, 2003 | 02:36 PM
vegeta6263's Avatar
hey guys i just finished puttting everything down on the engine after doing the premix everything seems good but the car won't crank
all u hear is the starting but it doesn't crank at all. I removed this one metal line by the omp it has like a arm on teh bottom and it went up by where the metal part on the top of the engine is i think that metal arm moved the engine to started ... im i correct?
it took me 2 days to do this premix u think it might be the battery?
Old Apr 28, 2003 | 02:50 PM
Cory Simpson's Avatar
I wanta be with the BUC!
What ???
Is the starter turning the motor, and if you can get a picture of what you are talking about or describe it a little better I have no clue what you are talking about.
J-Rat's Avatar
Alcohol Fueled!
the motor doesnt turn over?
Old Apr 28, 2003 | 02:54 PM
vegeta6263's Avatar
here u guys know where the 3 vacumm hoses connect one rigth under the other one.
the first one( on top ) is a bit fatter in diammeter and the one sunder it are of teh same size and skinneier.
on the left of it ull see what looks like a belt is like yellowish metal and u can turn it withyour hand to teh left and when u turn it it turns soem metal right on teh back..
dr0x's Avatar
pei > caek
I think the rod he is talking about runs from the OMP to the front of the tb.
vegeta6263's Avatar
no, the motor doesn't turn over
Old Apr 28, 2003 | 02:56 PM
vegeta6263's Avatar
yeah i think tahst the one, it has like a Q arm taht moves at the bottom with like a spring . do i need it? coudl it been teh battery??
Old Apr 28, 2003 | 03:05 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
ok guys I was helpping him out with the aid of my wrie-up. The little are he is taking about is the one that connects to the OMP. I am thinking he left something disconnected.
Old Apr 28, 2003 | 03:12 PM
Turbonut's Avatar
If you hear just s "clunking" sound the starter is probably going into the flywheel, but not enough juice to turn the engine over. Check your interior lights. Put them on, hit starter. If lights dim to almost nothing, battery problem. Did you leave lights on, doors open, radio playing while you were working on your car?
Old Apr 28, 2003 | 04:26 PM
All that rod does is controll the amount of oil that will be injected into the engine and the intake. If you removed the OMP then you don't need it. Did you take the whole system out???
Old Apr 28, 2003 | 04:35 PM
vegeta6263's Avatar
there is gas dropping down by the fue injectors..
Old Apr 28, 2003 | 05:52 PM
rgordon1979's Avatar
LS what?
you didn't put something back together right. I would try to find a good rotary mechanic in your area to help you figure this out.
Old Apr 28, 2003 | 06:08 PM
SonicRaT's Avatar
Super Raterhater
If you got gas dripping from your injector area, don't even dare start that thing, you're only asking for a fire.
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
torky007
Aug 17, 2015 05:14 PM
