Help - Motor Rebuild? (kinda long)
Old Apr 28, 2003 | 12:19 PM
kllntyme's Avatar
Legend in my Spare Time
My beloved rex sat for three days and didn't want to start. Acted like a lack of compression and my relatively new plugs showed a little carbon coating. To get it running I had to resort to the ATF trick for the second time in three or four months. I go out of town often on the weekends and don't take the RX. This means that the car sits for two or three days at a time every couple of weeks.
Does this sound like I need to rebuild this engine soon, or is there some other simple problem that I don't know about. My mods and removals are in my sig. Please give me some input on this issue. If I need to rebuild this engine, then I need to step up efforts on my Supra project and make room for the rex. I'd just like as much warning as possible. Thanks.
Old Apr 28, 2003 | 12:57 PM
Dvst8's Avatar
Going for the win
get a compression test, do a tune up, check for leaks vaccum hoses, unflooded it....do some tests.....
dont think your engine can get screwed just by sitting for 2-3 days....
Old Apr 28, 2003 | 08:30 PM
kllntyme's Avatar
I don't think it got screwed in 2-3 days, I think it may be too worn and/or too coated in carbon to continue running trouble free for long. As for the tune up, it was done about 1500 miles ago... and no, I didn't use that set of plugs with the ATF. I keep an old set just in case. I'm also running Accell 8.8 wires and 93 or 94 octane gas. Unless both times were caused by sub-par gasoline not burning clean, I'm trying to figure if I need to work a rebuild into my budget.
Old Apr 28, 2003 | 09:44 PM
Joonas's Avatar
use lower octane gas Rotaries run better on the cheap stuff
Old Apr 28, 2003 | 09:48 PM
JDMkamikazeeRX's Avatar
Really you need to just check you compression. If you have done it, post it here so we can see it.
Old Apr 28, 2003 | 11:13 PM
rotary>piston's Avatar
might just be flooding too. Al you need to do to solve that is get the injectors cleaned.
cristoDathird
28
May 30, 2019 08:47 PM
incubuseva
14
Sep 3, 2015 12:37 PM
rxmiles
Aug 24, 2015 02:07 PM
