Replacing thermostat
Old Apr 28, 2003 | 07:57 AM
Fingers's Avatar
1) how hard?
2) where the hell is it?
3) could it be the cause of your engine running warmer than it's supposed to? (not alot, barely a needle-width over half, always been like that)
Old Apr 28, 2003 | 07:59 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
1 easy
2 on the filler neck you remove it by two bolts and replace the gastket
3 yes
Old Apr 28, 2003 | 08:01 AM
Fingers's Avatar
Spank you!
Old Apr 28, 2003 | 08:03 AM
Turbonut's Avatar
Follow upper radiator hose from radiator to motor. Where it connects, is the thermostat housing. Remove 2 bolts, remove housing, clean surfaces, install new thermostat, replace housing. Replace with Mazda thermostat. Aftermarket gauge, or factory gauge? If it hasn't been replaced for a while, you sure can't hurt anything. Cheap insurance.
Old Apr 28, 2003 | 09:06 AM
SureShot's Avatar
Seduced by the DARK SIDE
On the stat - under the main valve - is a spring loaded disc. I covers a bypass port just under where the stat sits. The Mazda brand stat will fit. Some aftermarket stats don't close that bypass port properly.
Old Apr 28, 2003 | 09:13 AM
RXHEVN's Avatar
yes it DEFINITELY can affect temperature.I changed my thermostat and saw a drop of at least 10 degrees celcius (sorry dunno conversion to farenheit) recorded on my microtech so go and change it...AND dont forget to use a gasket ..if u cant get one a thin piece of cardboard and some silastic glue works..its on my car with no probs .hope it helps
BLK 93
11
Sep 9, 2015 10:56 AM
Frox
Sep 8, 2015 08:36 AM
Enzo1944
Sep 6, 2015 08:57 AM
