Sponsored by: CARiD
Air Pipe question(CAT. Convertor)
Old Apr 27, 2003 | 05:42 PM
jgrts20's Avatar
Who are you?
Exclamation Air Pipe question(CAT. Convertor)
hey y'all i need to replace my CAT. on my exhaust!! My question is: CAN the air pipe goin' into the CAT. be disconnected and will it effect the way the car runs(if i disconnect it and put an aftermarket CAT. on)?
any suggestions on what kinda CAT. i can get?
thanx, PEACE!!
86 RX7 gxl
13b
dynomax 2.5" CATBACK
cool air intake
Racing Beat Downpipe
Old Apr 28, 2003 | 09:53 AM
Cosmo Donk's Avatar
Queer
You have to have that air pipe for your cat to work correctly. IF you remove it your cat will die a premature death and you probably will not pass emissions.
Old Apr 28, 2003 | 07:38 PM
jgrts20's Avatar
Who are you?
thanx Cosmo, but i was talkin about puttin' like a free flow cat.(Toucan or a Racing beat presilencer on) The emissoin test doesnt matter cos i know the guy that inspects my car(just checks lights, horn, ect.) it never leaves the ground!! I really just wanted to see if i can run the airpipe disconnected!! thanx again Cos!!
Nice car by the way Cos!!
Old Apr 28, 2003 | 11:39 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
if you still have the stock lower intake manifold and you have the sleeves in there... you might want a cat there for the back pressure... to operate the sleeve open... a high flow cat will do, but you want the air pipe there for that because that's where your actuators get the pressure from...
Old Apr 29, 2003 | 11:40 AM
Cosmo Donk's Avatar
Queer
Yah, what he said. There are posts out there about having the 6-ports being electronically actuated or just using the ACV to open them via the air pump I think but I don't know much about that stuff.
Thanks.
Eric
Old Apr 29, 2003 | 04:27 PM
MRGSL-SE's Avatar
hey donk..!!! how did you get a QUEER for a STATUS....???
back to the subject... you could open the sleeve with the AIR PUMP... but its gonna be open all the time... unless you get a device that stores pressure and release at certain rpm...(that's expensive)
Old Apr 29, 2003 | 09:47 PM
jgrts20's Avatar
Who are you?
hmmm interestin' thanx y'all, my CAT is shot so i have to do something!!PEACE!!
Old Apr 30, 2003 | 10:13 AM
Cosmo Donk's Avatar
Queer
I guess they just don't like me Actually you can change it to anything you want in the User Control Panel.
I can't remember what they did with the air pump but I thought they had some kind of pressure valve or something goofy. I am sure you can find some way to fix it out there.
Old Apr 30, 2003 | 12:25 PM
jgrts20's Avatar
Who are you?
thanx Cos, anyway u've been helpful!! sound like u know ur sh*t though on these cars!! PEACE!!
12abridgeport
Aug 17, 2015 06:28 PM
