ECU & P.S. Grounding Wires
Old Apr 26, 2003 | 07:45 PM
Liquid Anarchy's Avatar
We come with the Hardcore
89' GTU
Which wires am I supposed to ground? I grounded the black striped wire on the Pressure Sensor, and a green and black one from the ECU. Now my car is having trouble starting... what's up w/ that?
Old Apr 27, 2003 | 06:31 AM
NZConvertible's Avatar
I'm a boost creep...
Green/black is not an ECU ground wire...
Regrounding the ECU
Old Apr 27, 2003 | 07:35 AM
SonicRaT's Avatar
Super Raterhater
I believe the green/black is one of the injector wires, which would mean you have a constantly firing injector. I can only imagine how flooded that would get!
Old Apr 27, 2003 | 03:25 PM
last time I use a picture of the 'net. Thanks guys, simple problem simple solution.
Old Apr 27, 2003 | 06:06 PM
HAILERS's Avatar
HAILERS
EEEEEK! Like the man said, if the green/black is on the small plug and its light green/black, its an injector (rear primary).
If it's on the largest plug, its for the Neutral switch. If its on the second largest plug, its for the metering oil pump. Not Good at all.
So which plug is it on??? And we'll tell you how many dollars it cost to fix.
Er, ah, take the ground off the green black
By the way, the grounds are on pins. 3C,3D, 3A, 3B on a 91 model. See page FI-80/81 of the online manual.
The Shaolin
Sep 14, 2015 07:50 PM
Akaviri
Aug 31, 2015 04:41 PM
PhillyFC
Aug 21, 2015 06:36 PM
