What is this and what does it do??
Old Apr 26, 2003 | 07:05 PM
sonic7's Avatar
Can anyone tell me what the heck this thing is and is it required. Can i remove it and put a block off plate there. I have no emmissions. IF someone could take a picture of where ever theres plugs in that would be grately appreciated!!! Thank you all...
Justin
Old Apr 26, 2003 | 07:07 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
I believe that is your BAC valve. If you have accesories do not take it off. I removed mine but i have no a/c or power steering. The BAC adjusts the idle under different loads.
Old Apr 26, 2003 | 07:09 PM
sonic7's Avatar
so, I dont have those, and it is useless!!! ha ha haha ha.... less weight!
Old Apr 26, 2003 | 07:10 PM
AreExSeven's Avatar
Huh?
That is your BAC valve. Its use is to raise the idle when the engine is under load. Those 2 connections are for a coolant line that runs from the top of the water pump housing to the back of the throttle body. It serves only as a connector, as the coolant does not flow into the BAC valve, just past it. You remove those lines when you do the Throttle Body mod, which was probably done by the previous owner.
Old Apr 26, 2003 | 07:12 PM
sonic7's Avatar
no... see, the thing is... i tore the s4 motor out in a mad rush of excitement about 4 months ago and put a s5 in and did stupid things.. i took the motor back out and just recently reinstalled it.. forgetting where things went! I was retarded to do it in such a hurry, now am paying for it. Thanks guys,
Justin
Old Apr 26, 2003 | 07:16 PM
AreExSeven's Avatar
Huh?
Ah, in that case, there is a small coolant nipple on the top of the water pump right below the alt (at least on S5 Turbo), and a coolant nipple on the top of the TB, right where it meets the UIM (again, on S5 Turbo). Run a line from each of those to either side of the BACv.
Old Apr 26, 2003 | 07:18 PM
sonic7's Avatar
unless i dont have, ac and other accessories, would i just run a hose between the two?
Old Apr 26, 2003 | 07:19 PM
1987RX7guy's Avatar
yeah I have mine blocked off
Old Apr 26, 2003 | 07:20 PM
sonic7's Avatar
thank you very much!!!
Old Apr 26, 2003 | 07:21 PM
AreExSeven's Avatar
Huh?
You could do that, yes. But If you do the TB mod, you can eliminate the hose altogether.
Old Apr 26, 2003 | 07:22 PM
sonic7's Avatar
what is the Throttle body mod?
Old Apr 26, 2003 | 08:22 PM
Spawn VII's Avatar
TB mod is the elimination of the extra set of secondary throttle plates (and in most cases along with the bunch of crap around the throttle body that's not needed when removing those plates)
