I Need Wheel Offset's For 8.5 inch Wheels
Old Apr 26, 2003 | 06:58 PM
ShaunB's Avatar
I want to run the adr m-classic wheels but they only come in 8.5 which is fine, but the offsets are 15, 40, for 18's and 19's come in 35, i would like to run them in the front and back, which ones will work, thanks guys
Old Apr 26, 2003 | 08:26 PM
bkapold@aol.com's Avatar
18 and 19's are big wheels, but the offset you want is 35mm or 40mm....Those both will work with that wide of wheel
brad
Old Apr 26, 2003 | 08:34 PM
ShaunB's Avatar
Well They do have 17x7.5 but i would rather have wider, im gonna need traction, alot of it when i get done with my car.
Old Apr 26, 2003 | 08:35 PM
ShaunB's Avatar
Can any one photoshop the adr m-classic rims on a grey rx7, K8 Tornado silver, possibly 18'', thanks
Old Apr 26, 2003 | 09:34 PM
Turbonut's Avatar
If you have 7" rims now (stock 40 offset), the 8.5" with 35 offset will move the wheel 14mm (@9/16") closer to the strut. I can't see how they will fit without hitting the suspension.
Try this:
http://toy4two.home.mindspring.com/offset.html
Old Apr 26, 2003 | 11:13 PM
hypntyz7's Avatar
I run 18x8.5s all around, +37 offset. That is NOT enough offset for the inside clearance, I am running 1/4" spacers as well and Im still RIGHT there within 1/8" of the struts up front, even with skinny (225-40) tires. See pic below.
