12a hard 2 start
Old Apr 25, 2003 | 07:03 AM
ausrotaholik's Avatar
Newbie
Angry 12a hard 2 start
just put 12a carby into 1978 323 wagon, have 2 turn engine for ages before fires, engine sat for few months while doing conversion, has spark and fuel what is atf trick? any help appreciated.
Old Apr 25, 2003 | 08:03 AM
make sure the timing is right
also check compression if you can, sometimes if an engine is losing compression it takes harder to start it.
Old Apr 25, 2003 | 08:10 AM
Newbie
timing is sweet, car runs good once going, what is atf trick with motor?
Old Apr 25, 2003 | 06:54 PM
Cody's Avatar
SKELETOR!
My car does the same thing, started right after the secondaries conversion.
You have to turn it over a good couple tries before it will ever fire up, and once it does start to fire, it dies if you touch the gas or the choke.
I am thinking it is flooding out when I touch the gas, which means too much fuel at startup.
Whats the cure for that?
Old Apr 25, 2003 | 11:00 PM
wwilliam54's Avatar
it WILL run
pour about a tbl spoon of MMO in each rotor houseing
turn the motor of a few times and then let it sit a day or so
or you can use ATF fluid
Old Apr 26, 2003 | 12:40 AM
lol this is stupid but did ya check the leads... ive done it a few times... although i think has something to do with it sometimes....
Old Apr 26, 2003 | 01:12 AM
RotaryMotorDisorter's Avatar
hmmm, seems like alot of you 1st gen guys partake of the herb. Guess i fit right in! I might try that tbl of mmo and see what happens. (for my engine) im talking about. HAHA
Old Apr 26, 2003 | 02:23 AM
Suparslinc's Avatar
It's Back!
if the engine doesn't fire on the 2nd or 3rd turn, then you probably have some sort of ignition problem such as plugs/timing.
edit: no real cure for the too much fuel problem, if you are experiencing this problem during hot start. . . to quote a fellow rotorhead:
Leaking fuel inlet valves or float level too high causing flooding would be my guess. The fuel evaporates overnight, so the motor starts right up on the choke in the morning.
Old Apr 26, 2003 | 03:10 AM
Keaponlaffen's Avatar
My car has always done a "wind-up" start as Paul (Vohaul on this board) calls it.... it starts slow, cranking, then over the space of about 2-3 seconds, it gradually speeds up until it finally fires and starts. It's probably just because of the lower compression on the engine....
Th0m4s
Feb 26, 2019 02:04 AM
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
