How much did you pay to replace your Bushings?
Old Apr 24, 2003 | 11:46 PM
frank69m's Avatar
Cool How much did you pay to replace your Bushings?
Just need to get a gauge...How much did you pay to get your bushings replaced...I know most of us have had to go thru this...
thx,
Franko
94 FD
Old Apr 24, 2003 | 11:56 PM
ttb's Avatar
ttb
No Cup Holder Racing
think it's anywhere from 700-1200 bucks.
Old Apr 25, 2003 | 12:23 AM
rynberg's Avatar
It is over $800 in PARTS just for all the rear suspension bushings (unless you go through Malloy Mada or Mazdaformance).
Old Apr 25, 2003 | 12:30 AM
ttb's Avatar
ttb
wow, i didn't know the parts were so expensive. i thought most of what i paid for was labor, but i guess not.
Old Apr 25, 2003 | 12:34 AM
rynberg's Avatar
Yep, I have kept full records of every $ I have spent on maintenance or modifications. Considering I'm still fairly close to stock, the total expenditure is very scary....
Old Apr 25, 2003 | 12:43 AM
frank69m's Avatar
Holy crap!! Is it really that much.... almost $1,000 to get them replaced. Guess I'll need to flip more burgers.
Old Apr 25, 2003 | 01:39 AM
GoRacer's Avatar
Speed Mach Go Go Go
I think I paid $400 for the bushings and $200 in labor. You can contact Mazdatrix and they can tell you which are the most common bushings to wear out. They can also install them as they did mine.
Old Apr 25, 2003 | 11:27 AM
frank69m's Avatar
Hey GoRacer, how long did they take for the installation and did they also do an alignment? Isn't it hard to get an appointment at Mazdatrix?
Old Apr 25, 2003 | 06:10 PM
GoRacer's Avatar
Speed Mach Go Go Go
I think I was there for 6 hours but it probably was only 2 hours labor. I would have to open my receipt book and check.
No, I had my alignmen done at Tri-Point but there is also a company in the city of Orange that Racing Beat recomends.
Yes, extremely dificult. I had to wait two weeks for two months. Jon is the only mechanic and is allways swamped. If I remember him correctly, he also worked for Racing Beat and MazdaComp (alot of experience).
Old Apr 25, 2003 | 09:37 PM
rx7will's Avatar
I saw an estimate from Mostly Mazda and i think that wanted $350 to just do the rear bushings.
Old Apr 25, 2003 | 11:22 PM
wonder1and's Avatar
I Sold My Car 2 the Devil
I have done all of my bushings myself so far except for the front rubber ones (which I'm looking for time to get to) and the diff bushings (I'm uncomfortable w/ pulling an axle in my own garage w/ out anyones experienced help).
Here is a basic run down of what everything costs...
1. Basic pillowball bushings: 6 of them in the rear, ~$50 a piece, 2 in the lower control arm and one in the end of the wishbone.
2. Diff bushings (2)(~$60 bucks + labor of 3 hours at 65 a piece, on top of differential housing)
3. Large pillow ball bushings (2)($50~75, end of lower control arm where alignment bolt goes)
4. Jimlab bushing set ($350 + apex'i BOV )crapload of them... 8 that go in the front where suspension part bolt to frame, 6 in rear where suspension bolts to frame and also shock mounts, try and find a deal on these!!! they are usually 700 a set)
5. Tie rod ends for P/S rack (~$40-60, simple install except getting them off of the hub!)
Suggestions... look and find a friend that works at a shop. Find, borrow, buy compressor w/ a air hammer use this to remove the metal rings that hold the bushing in which makes pressing them out much easier! Find a crappy set of deep weld large sockets to use to press these suckers in and out.
Additional info: all of these bushings besides the jimlab's were purchased through Eric Smith at roger beasly maz-duh in Austin, Tx 512-459-0009 (tell him Ryker gave you his number and he will hook you up)
**yes this crap can get fairly expensive and time consuming but doing it yourself will save quite a large amount of $!!**
Good luck!
Ryker
P.S. pm me if you have any questions!
Old Apr 26, 2003 | 01:17 AM
particleeffect's Avatar
omgwtfposlol
hrm from that I'm seeing something like ~1390$ for all the bushings. or is it another ~400 for comp toe links and trailing arms in the rear? not including any labor.
no, I so much do not want to do this.
not to change the subject, but about how many miles should new bushings last? "nylon" bushings?
Old Apr 26, 2003 | 03:12 PM
wonder1and's Avatar
depends on the driving...of course... O and I forgot to mention the M2 control arms and toe links... that was a pretty penny. I will be selling a spair set of stock toe links I believe (the one w/ 1 bushing in it on each side) soon w/ the jimlab bushings in it for a decent price... I'll keep yall posted!
Old Apr 27, 2003 | 12:21 AM
tekno62's Avatar
toe links
Wonderland, when you sell the toe links please PM me.. I would like first crack at them
Old May 27, 2003 | 08:25 PM
DaedelGT's Avatar
Uber Newb.
Sorry for the big bump but I thought I would mention Gotham Racing quoted me at 4 hours labour for the rear bushings.
autoxer
21
May 22, 2019 04:07 PM
82streetracer
Aug 23, 2015 09:28 AM
RaY358
Aug 19, 2015 11:44 PM
GrossPolluter
Aug 15, 2015 10:32 PM
