miata rears
Old Apr 21, 2003 | 04:23 PM
jayroc's Avatar
miata rears
I've heard the 94-97s fit, but is there a way to make the '90 version fit?
Old Apr 21, 2003 | 04:35 PM
Montrealer's Avatar
Swapping the later 94+ rear into a 1990-93 Miata is a bolt-in but requires replacing the entire diff housings assembly, driveshaft and half-shafts from the later 1994+ cars
Source: http://members.aol.com/solomiata/Drivetrain.html
It will probably not fit the 84-85 disc brake axles...
Old Apr 21, 2003 | 05:18 PM
TheTwinTurboRX-7's Avatar
when speaking of the rear, would that be just the gear pumpkin, or the whole thing??
Old Apr 21, 2003 | 06:16 PM
jayroc's Avatar
just the pumpkin
Old Apr 21, 2003 | 06:21 PM
jayroc's Avatar
What's the definition of a third member?
Old Apr 21, 2003 | 06:25 PM
moremazda's Avatar
Gone Race'n
The third member is the thing that holds all of the gears, the pumpkin is the housing.
Old Apr 21, 2003 | 06:33 PM
Directfreak's Avatar
I am a Jeeper Now.
Old Apr 21, 2003 | 06:35 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Originally posted by Directfreak
So what's the first and second member?
Old Apr 21, 2003 | 06:46 PM
so the 94-97 miata rear will bolt into our car, or am I just confused
Old Apr 21, 2003 | 06:58 PM
jayroc's Avatar
Yeah, me too.
A better question for me is:
Can I just bolt in a 94-97 miata thirdmember?
Old Apr 21, 2003 | 07:49 PM
Cody's Avatar
SKELETOR!
1st member - engine
2nd member - Transmission
I think.
Old Apr 21, 2003 | 07:58 PM
Turbo Driver
I' new to all of this, so I want to ask a few questions.
are you talkign about swapping an independant rear from a Miata into a FB? Is that possible? And other than the independant rear, what are the advantages, and is is really worth it?
My local junkyard has a '95, and I'd do it if it was worth it. Otherwise, I'll see it to one of you who thinks it is.
Old Apr 21, 2003 | 08:00 PM
Kill No Cone's Avatar
Jayroc, the 90 Miata has a smaller diff than first gen cars and will not work.
There are two reasons folks go with the Miata third members; one, the gears (some have 4.10 and others have 4.30); send the Torsen diff that is available in a few models.
So to make this work in a first gen you need an 84-85 rear with the larger axles (either GSL or GSL-SE). This process will not work for an earlier rear axle housing.
Old Apr 21, 2003 | 08:05 PM
Turbo Driver
Hmmm, I'll have an SE, so I could do it.
But yo're only using the differential right, not half shalfs and htings like that, so in other words, you would have independant rear.
From what I know, if the Miata had cruise control, it has the lsd, the one I spoke of has it.
So would it be worth it to do this to my SE? What gears does it have, and is the Torsen LSD any better than what is currently in the SE?
I just want to know if this would be justified. It would cost me very little, but that's beside the point.
Old Apr 21, 2003 | 10:57 PM
The GSL-SE has a gear ratio of about 4.07 or 8 (I do not recall the specific numbers off the top of my head). So, if you get a 4.10 rear gear then there will not be much of a change; but the 4.30 you will get a boost.
The third member in the GSL-SE is actually stronger than the Torsen rear end. If you are drag racing then you want the LSD. If you are road racing or autocrossing the Torsen is the hot stuff. It will help you exit corners.
How to find a Torsen rear end? I understand that you look for a 94 to 97 Miata with a stick and power windows.
Hey, good luck!
Old Apr 21, 2003 | 11:32 PM
Pele's Avatar
Right near Malloy
Nah... I've browsed the Miata Forums... That power window or cruise control rule is only 99% true... Too much error for my taste... Real test is to open the fill plug and see vertical worm gear or spider gears, or somethig like that...
Unless I read wrong, which I tend to do a lot.
Old Apr 21, 2003 | 11:55 PM
Good point, that is an accurate test method.
But, before I crawl underneath I would like to have an idea that the car has what I want.
Old Apr 22, 2003 | 09:59 AM
Sammymatik's Avatar
So has anyone done this Miata diff. swap? How difficult is the swap and are the results worth the effort? A torsen diff would be kinda nice to have though.
Old Apr 23, 2003 | 08:59 PM
Turbo Driver
yeah, I'd like to know more about it. The rear end I can get only has about 50k miles onit, vs. the 23xk I have on the car now....
Old Apr 23, 2003 | 09:17 PM
sounds nice
I'd love to pick up the torsen diff to put in the GSL rear I put in my car so it will stop whining, always be a good thing
Old Apr 24, 2003 | 12:12 AM
fatboy7's Avatar
Got Boost?
The actual clutch LSD part of the diff isn't whats whining.... its the ring and pinion. So if you do the swap don't forget the ring and pinion, and to get them adjusted correctly.
astrum
24
Nov 15, 2017 08:44 AM
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
