Bad to rev engine?
Old Apr 17, 2003 | 10:19 PM
RX-187's Avatar
live fast. die fun.
Question Bad to rev engine?
I want to know if it is bad to rev the engine because according to the owner's manual you should never rev the engine equipped with a turbo charger.
Old Apr 17, 2003 | 10:21 PM
rynberg's Avatar
Re: Bad to rev engine?
WTF?
Yeah, that 8000 rpm redline and 6500 rpm power peak are just for show. None of us rev our cars over 3000 rpm.
Old Apr 17, 2003 | 10:24 PM
Mahjik's Avatar
Mr. Links
Do you mean revving while sitting in neutral?
Old Apr 17, 2003 | 10:27 PM
RX-187's Avatar
live fast. die fun.
yes, exactly. So the beef continues Rynberg?
Old Apr 17, 2003 | 10:31 PM
Mr rx-7 tt's Avatar
rotary sensei
No.
Mahjik's Avatar
Mr. Links
Well, the car will blow off anything past around 4 PSI to not overwork the turbos without engine load. I imagine though, as long as the car is warmed up, there isn't a lot of harm that can happen. Although I'm not sure why you would want to do it (for a prolong period of time that is).
Heck, we all have to do it at sometime while fixing problems on the car. The manual also says not to use Synthetic oil which a lot of people do so I wouldn't worry about it too much.
Old Apr 17, 2003 | 10:32 PM
RX-187's Avatar
live fast. die fun.
............I asked a simple question
Old Apr 17, 2003 | 10:33 PM
RX-187's Avatar
live fast. die fun.
Smile That a man
Thanks Mahjik!
Old Apr 17, 2003 | 10:48 PM
turbojeff's Avatar
Do it right, do it once
I'm not sure what chapter of section of the owner's manual your referring to but Mazda thinks it is OK to rev it up so go for it.
Run it hard, change the oil often (like every 1500-2000 miles) and drive it mellow for the last couple miles before you shut it down. End of story.
Old Apr 17, 2003 | 10:59 PM
RX-187's Avatar
live fast. die fun.
Thanks for the advice turbojeff, and may I add-"and let the turbo timer do its job."
Old Apr 17, 2003 | 11:19 PM
rynberg's Avatar
I apologize for my sarcasm (sincerely). If you go back and read your question again, you could see how it could be interpreted as a silly question.
I'm not sure what you mean by "the beef continues". Have I pissed on your parade before?
Old Apr 18, 2003 | 12:08 AM
turbojeff's Avatar
On the turbo timer...
I actually think they do more harm than good. If you drive off boost for the last few miles the engine compartment gets lots of airflow. This cools the coolant and engine compartment in general.
Watch the temp guage while the car sits and idles, it'll rise up to 226F before the fans come on.
I've been seriously playing with turbo RX7s since '96 and really believe that turbo timers are a waste of $$.
Old Apr 18, 2003 | 01:21 AM
maxcooper's Avatar
WWFSMD
Perhaps the warning is to prevent people from overrevving their engines. Especially with the stock flywheel, it revs up slowly at first and then revs up exponentially quickly as the revs rise. If you aren't expecting it, it would be easy to rev right past redline.
-Max
Old Apr 18, 2003 | 01:45 AM
skunks's Avatar
I'm a CF and poop smith
well if you warm the engine up, its fine to rev to redline
Old Apr 18, 2003 | 04:23 AM
BuiltForBoost's Avatar
Does running into the rev limiter during boost cause any problems? It seems that the rev limiting fuel cuts would let it run extremely lean for a split second. Or does it blow of fast enough?
Old Apr 18, 2003 | 06:17 AM
vudoodoodoo's Avatar
Re: Re: Bad to rev engine?
Originally posted by rynberg
WTF?
HAHAHAHA
Old Apr 18, 2003 | 07:00 AM
RonKMiller's Avatar
Blow up or win
Is that like "Pissin' in the chilies?"
Old Apr 18, 2003 | 10:36 AM
rynberg's Avatar
Ron, you seriously crack me up. I don't know which is funnier, your one liners or your ghetto mod posts.
Old Apr 18, 2003 | 11:01 AM
Syncade's Avatar
heh heh, engines are built to be run
reving comes with running
i dont see a problem here lol
Queppa
Nov 18, 2024 03:47 AM
Kyo
Apr 13, 2019 09:24 AM
C. Ludwig
Jan 30, 2019 06:31 AM
gtcd
30
Aug 19, 2015 02:44 AM
morataya
Microtech
Aug 17, 2015 01:04 PM
