How do I get 114.3 wheels on a GSL?
Hey peoples.
I'd like to be able to use the 4 x 114.3 wheel size which comes stock on a GSL-SE, on my 4 x 110 GSL.
I have an almost brand new set of 17" Motegi MR7 rims, with 205/40/17 Yokohama Parada Spec II tires just sitting in storage waiting for me to figure this out.
What all is needed for the swap? Is this a simple project, or do I have to drag almost the whole parts car home when I find one to do this?
Or, from another angle.....do they make any sort of adapter that would just basically bolt to the 110 hub to make it fit a 114.3 wheel?
Thanks in advance for all replies
this subject has been beaten to death
LOL Just incase the search isnt working, you swap the front struts assy, complete with rotor, spring, brake calipers, brake brackets etc. Then you swap the entire rear end... Everything is a bolt on, doesnt get much simplier than that
I definately have to switch brakes? I have heard that the GSL-SE brakes are better, but, I don't expect to find great brakes on a parts car. There isn't a way to just switch hubs?
Trending Topics
Originally posted by Felix Wankel
No, the spindles, rotors, calipers, and brackets are totally different.
LOL
Ok here it is for the 100th time..
If your car is an 84/85 and you want to put the SE set up on this is what you need.
The brake booster stays,they are the same...
You will need:
The SE master cyl
The SE front strut assembly/unbolted from the lower arm,and trut tower.
The SE front rubber hoses.
The SE whole diffrentual (rear end)
with the 3 brakes hoses back there,
The SE E brake cables
Pre 84 needs
The 84/85 brake booster
The SE master cyl
ANY 84/85 drive shaft
You will need:
The SE master cyl
Pre 84 needs
The SE master cyl
