great, just great, starting problem
Old Apr 14, 2003 | 11:36 PM
Rx-7$4$me's Avatar
So I go out to get food, come back, shut off the car, go out to restart it 15 min later. NOTHING I turn the key over, and I just hear a buzzing noise, and the fans that stayed on when it came back on, shut off when I turn the key over. The lights dim and everything but the engine doesnt even turn over. I dont need this right now, can someone please help.
Turn key over, nothing happens, I here a buzz (its not the fuel pump), and nothing.
Old Apr 14, 2003 | 11:47 PM
Rx-7$4$me's Avatar
checked battery, its fine
Old Apr 14, 2003 | 11:50 PM
Jason's Avatar
The one
The car doesnt crank at all?
Jason
Old Apr 14, 2003 | 11:59 PM
poss's Avatar
Slower Traffic Keep Right
could be the starter or something in the wiring to the starter.
maybe the termial on the starter wiggled loose.
Old Apr 15, 2003 | 12:01 AM
Rx-7$4$me's Avatar
but how??? all I did was drive it and park it and then it just stopped. doesnt turn AT all, but the lights dim, and everything like its draining the amps to crank
Old Apr 15, 2003 | 12:05 AM
Rx-7$4$me's Avatar
if I get on the side of the car can I see the starter terminal
Old Apr 15, 2003 | 12:10 AM
Rx-7$4$me's Avatar
I thought maybe my clutch switch was gone, cuz thats what it does when the clutch isnt gone
but I pushed the button and it makes a noise... so
Old Apr 15, 2003 | 12:17 AM
Rx-7$4$me's Avatar
well I went out and SMACKED the starter, and it fired up
Old Apr 15, 2003 | 12:18 AM
Rx-7$4$me's Avatar
so my starter is going
Old Apr 15, 2003 | 12:19 AM
dclin's Avatar
Perpetual Project
Yeah, my starter ground cable was loose recently. Would not turn over at all. Ready to order a new starter, when I noticed the loose connection.
Cleaned the connection, tightened it down, and it started right back up.
Old Apr 15, 2003 | 12:21 AM
dclin's Avatar
Perpetual Project
Try undoing both the power and ground cables - clean the connections with sandpaper, and snug tight. Probably has a build up of crud to prevent a good connection.
Old Apr 15, 2003 | 02:38 AM
Rx-7$4$me's Avatar
ok, I'll try that on thursday when I have access to a lift
Thanks!
Old Apr 15, 2003 | 04:06 AM
skunks's Avatar
I'm a CF and poop smith
how did you check the battery?
did you try jumping it yet?
Old Apr 15, 2003 | 12:02 PM
Shinobi-X's Avatar
Sensory Experience
A basic way to check the battery is to turn on your interior lights, and trying to start the car. If they flicker or dim, it's usually a good sign that the battery is going. (This is assuming it's not the starter, or that it's been previously checked.)
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
