Where to mount the stock ignition coils after taking out stock hard fuel lines?
Old Apr 14, 2003 | 06:01 PM
c00lduke's Avatar
I've seen one thread on this but couldnt seem to find it again, I was just wondering where you guys that replaced the stock hard fuel pipes mount your stock Ignition Coils? There doesnt seem to be any place on top of the block and doesnt seem that there is room where the cruise control used to be. Any ideas?
Thanks
~Luke
Old Apr 14, 2003 | 06:54 PM
duboisr's Avatar
Garfinkle has done this and the lines look great ,custom fuel rail and all. The leading coil is a harley-crain coil mounted on the fender wall below the brake master cylinder. There is a small flat place to bolt to. the stock trailing coils are mounted on the stock mounting box that has been cut down and welded to a bracket . It is mounted to the fender wall beside the brake master cylinder above the leading coil. For more info you could call Gar in Murfreesboro Tn , Get a torque brace when you call
