cut secondary spring
Old Apr 12, 2003 | 09:41 PM
Forgie's Avatar
alright I think I may have done something really stupid....I read a few days ago that if you cut the spring for the secondarys down a little bit they would kick in earlier. well........I cut about an 1/8 of an inch off the spring, and now my car sounds really rough at idle.... and when I poped the hood the carb was making a loud buzzing noise....any way.....I was wondering if anyone could tell me what to do in order to fix this. I think the secondarys may be stuck open.
Old Apr 12, 2003 | 09:50 PM
WackyRotary's Avatar
standard combustion
You probably didn't reconnect something when you had the air cleaner off maybe? Cuting the spring will NOT cause that.
Old Apr 12, 2003 | 10:01 PM
Forgie's Avatar
like one of the rubber hoses?
Old Apr 12, 2003 | 10:15 PM
Forgie's Avatar
alright ........I figured it out... when I bought my car one of the hoses running from the blue air box thing was capped off....it was a bigger hose on the drivers side of the carb....but yeah I must have re-installed it when I put the blue thing on.....anyway I capped it off again and now it's running fine......
thanks tho.
Old Apr 12, 2003 | 11:36 PM
Nick Gibilisco's Avatar
I was thinking of cutting mine on my 84, Do you notice any difference, Is it woth cutting down, my car is completely stock and runs great as is. Just wondering ???
Old Apr 13, 2003 | 04:45 PM
Forgie's Avatar
honestly, I'm not sure it really made a difference. I might not have cut enough off
Old Apr 13, 2003 | 05:58 PM
NanaimoRx-7's Avatar
I didn't notice much of a difference running 1/4 spring until I swapped it out for 3/4 spring and went for a drive. I flored and was like waiting...waiting...waiting... ahh there we go a little power. Now I'm on mechanical secondaries, WORLD OF DIFFERENCE, full go by 3500 RPM. None of this waiting til 6K for power BS. Oh yeah, best part.... it's free.
Old Apr 13, 2003 | 10:09 PM
standard combustion
I found with other people I've helped, that mechanical secondaries work best with headers. One worked well with out the header, but the other didn't? So I'm guessing something was wrong with his car. I'd rather go to mechanical then go the reduced spring or no spring route because its pretty garonteed the secondaries will open when you want them to.
Old Apr 13, 2003 | 10:14 PM
Cortex's Avatar
My money is on doing Sterling's mechanical secondaries mod. That way you are in total control of how the secondaries are open at all times!
Search for "Carb crap" I think in the archive and you'll find it.
I was going to do it myself until I found that the friend I got my '83 off had already converted to secondaries.
..Matt
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
