my 1st gen sux
Old Apr 11, 2003 | 01:44 PM
fug_mo's Avatar
my 1st gen sux
i dont know if there is anything wrong with it or what.Ive got a 85 gs 12a.It drives and runs and idles perfect.Rebuilt motor by haynes 10k miles ago.All stock except for a muffler.took off smog pump,plugged of the lines when i did that,took off a/c,replaced clutch fan w/ electric fan,and put 14" rims on it.I got beat by a saturn and a kia.Dont even get me started on hondas.I dont have much money to make it much faster but is it supposed to be this slow?
Old Apr 11, 2003 | 01:49 PM
I don't know man, but my stock port was smoking all the hondas in site. A lot depends on how it is tuned up. An unproperly tuned street port can be as fast or slower than a stock port.
Old Apr 11, 2003 | 01:52 PM
Manntis's Avatar
add to cart
take off the stock manifold and cats and replace with a header and presilencer to go with your muffler - otherwise you still have serious exhaust restriction slowing you down
Old Apr 11, 2003 | 01:59 PM
fug_mo's Avatar
still stock port, any suggestions on how to tune it or what i should do besides the header?I just listed it for sale but if i can beat any hondas at all, i might keep it cuz its a really cool car and handles excellent.
Old Apr 11, 2003 | 02:19 PM
Randy Nix's Avatar
That don't sound right! Are you sure the secondaries are opening up correctly? If they are not opening then you've got a cute little economy car, when they open my rex roars good! Search on mechanical secondary mod.
Old Apr 11, 2003 | 02:46 PM
fug_mo's Avatar
i was looking at other people who say they had mech. secondary problems and some say they topeed out at 85, i got mine to 110 and it wouldnt gone up alittle more.Thats when the kia whooped me.Sometimes the car pulls decently in the mid-high range, but sometimes when im flooring it,im looking at my tach and can see the rpm going up but its like my car isnt going any where.i was thiking fuel pump or filter at first but they seem fine.It idles at 750-850, and drives real smooth, but also got beat by my dad extended cab f150 4.6 auto.Id hate to sell it but need the speed.
Old Apr 11, 2003 | 03:02 PM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
Is this car an automatic?
Old Apr 11, 2003 | 03:19 PM
RTBoy02's Avatar
He also lives in Houston, where there are actually fast Hondas, believe it or not. Winter Park is a bit different...
Old Apr 11, 2003 | 03:26 PM
Pedestrian X's Avatar
SpAz!
mebbe your clutch is dying??
Old Apr 11, 2003 | 03:28 PM
fug_mo's Avatar
yeah,tons of fast hondas, but i cant even keep up with a slow one.I just went outside,took off the top of the air filter housing, started the car and looked in the carb.I gave it some gas and kept giving it gas but didnt see the secondaries opening.I dont know if they'll only open when they have load but how do i check if they working?That seems like it is the problem.If so how do i fix it?Just convert to mech?
Old Apr 11, 2003 | 03:30 PM
fug_mo's Avatar
i thought about it being the clutch until last night.I raced a v6 camaro, dumped it @ 5-5500 and got 'em real good off the launch, then right when i hit 2nd he flew past me and got about 6 cars by the end of 2nd.It doesnt seem to be slipping, just dying real bad at the top end between 5500-7000
Old Apr 11, 2003 | 03:54 PM
Randy Nix's Avatar
Wiring the cecondaries together is easy, all you need is a wire tie. You can't really check the opening until the engine is under load with the stock vacuum opener. Mine pulls strong past 8K and it's stock as far as I can tell.
Old Apr 11, 2003 | 04:04 PM
firstgen82's Avatar
the 12a rx really does 0-60 in about 10 seconds in most condition...9 seconds if you get a good hook-up. I suspect as someone said, the secondary might not be opening up fast enough, you can check that by the linkage near the firewall on the passenger side. But best bet is to just Turbo 13b the car. You'll then will be complaining that it will keep spinning the tires in 1-3rd gear.
Old Apr 11, 2003 | 04:46 PM
fug_mo's Avatar
how do i wire tie it together and what does doing that do?i just now sprayed wd-40 all over it,and worked it open and close to get it lubricated, but what now?I had been running 87octane but after spraying it a 2nd ago i filled up w/93.It seemed maybe a little bit faster but it still wouldnt hang with anybody.
Old Apr 11, 2003 | 04:58 PM
took off air pump?
Clogged cat?!?!?!!!!!!!!!!!!!!!!!!11
Old Apr 11, 2003 | 05:01 PM
V8kilr's Avatar
not true, floor it to 6k in your driveway, have a friend look for you, they will open if they are working,
mine start lower then 6k with no load but I am just going on the safe side, 6k they should open.
sounds like one or both of these
1:fuel delivery
check fuel filter for rust deposits
check to make sure fuel pump is operating at proper psi rating
check secondaries as already stated above
check fuel line condition and for mulitple splicing or leaks
2:exhaust
replace cat with a straight pipe right off the bat with out any questions
look for a deal on a racing beat header or buy one new
your muffler is only making your car sound better until you replace these things mentioned above
good luck
Old Apr 11, 2003 | 05:42 PM
RacerX7fb's Avatar
paradox
Im with 79+80+84_rx-7
.. if you still have the stock cats yet you removed the air pump then all you are doing is clogging the cats up. A 12A GS puts out about 100HP at the crank.. dont expect to be beating modified Hondas with double the horsepower.
Old Apr 11, 2003 | 06:57 PM
851stgen12a's Avatar
Off riding sportbikes!
If you still have your cats on there, most likely there are getting clogged up.
My 85 gs was killing V6 mustangs, Camaros, and most of the ricer Hondas around here This was before I did any mods....
Its a whole lot faster now... and gonna be a whole hell of alot faster in a few months.
Old Apr 11, 2003 | 07:29 PM
moremazda's Avatar
Gone Race'n
www.mazdatrix.com
www.racingbeat.com
If you can't afford a full exhaust run a cat replcement pipe. The next big fairly cheap thing is to replace the mechanical fan with and electic fan. The exhaust and the mechanical fan are the two largest power robers these cars came with.
Good luck, oh and don't be ashamed of the v6 camero, they are pretty fast.
Ryan
Old Apr 11, 2003 | 09:04 PM
fug_mo's Avatar
i already replaced the fan w/ an electric.As soon as i get a chance im gonna get a header and take off the cats.I was gonna turbo it, i bought a bae turbo kit, but couldnt have my car sitting for long enough to install it.Ive still got it(minus the turbo and wastegate), ill trade it for a header, test pipe,and some drop springs.Maybe an aftermarket air filter too.
Old Apr 11, 2003 | 09:32 PM
rlking's Avatar
The Most Important " Go Fast" Part Of Any Car Is The DRIVER
Old Apr 11, 2003 | 10:23 PM
vipernicus42's Avatar
Rotoholic Moderookie
Does replacing the stock fan really make *that* much difference? I was kinda leaving it until later because I'm not going to be doing any more than a bit of road racing, and it fell to the end of the modlist...
Old Apr 11, 2003 | 10:44 PM
Metallic_rock's Avatar
Ride 'n Style
Question
Here's a thought. What kind of spark plugs are you running? You need to be running NGK's. Also, when was the last time the cap, rotor and wires were replaced. I know you said you got a new engine, but they dont' always replace that crap.
Other cheap performance enhancers- K&N air filter, run 92 octane always, and use fuel system cleaner every now and then. and REPLACE THE FUEL FILTER.
Old Apr 11, 2003 | 10:51 PM
Rex4Life's Avatar
RX-7 Alumni
I would think you could tell if the mix is starting to lean, you know that boggy sounding carb with no accel.
Header and high flow cat with RB muffler would help you gain some power. That's your biggest immediate gain for the dollar--and can be done emissions legal.
Pull some weight off the car.
Still these new cars with 250 HP are going to be tough for you to beat, but that's why they cost alot more.
Good Luck, Scott
Old Apr 13, 2003 | 06:46 PM
fug_mo's Avatar
my car is finally decently quick.This cable on the back that looks like a T but the top part threads up and down wasnt hooked up, so i wasnt getting full throttle.A guy named cody(dont know his screen name)fixed it.Thanx man.
