Sponsored by: CARiD
J-spec Turbo II engine 1989-91
Old Apr 11, 2003 | 01:36 PM
Miaka's Avatar
I need to find out how to get this engine cheap and who can tell me how or where I can get someone to install it into a nonTurbo A-spec 1986 Mazda RX-7. I can spend $1500 or so but not right away and I need to know is just rebuilding my crappy stock engine and getting turbo installed is better. I want J-spec though but can't always get what I want Any help would be appreciated. This is my first RX-7 and when I get a new engine it will race. Rotaries Rock!!!
Old Apr 11, 2003 | 02:37 PM
Cosmo Donk's Avatar
Queer
You might want to do a search for "jspec" or something similar to find a dealer. To get a turbo Jspec running in an NA you will need more than $1500, sorry Unless you get a front clip with the ECU but then you will have to stick with the NA tranny to keep under $1500. To change out the trannies and stuff it will be a lot of work. It has been covered quite a few times on this forum so you should be able to find some good info.
Eric
Old Jun 16, 2003 | 11:47 PM
White_Seven's Avatar
FC 2 NV
I am getting an 89-91 front clip within a week and am doing the same thing, an 86 N/A to T2 conversion. I'm pretty nervous about doing the swap. I've rebuilt and replaced a Nissan Z24 engine before, but that was pretty standard. But this stuff.....oh boy, what am I getting myself into. Anyhow try checking The Parts Trader , which is where I found my front clip (which is also including the tranny, d-shaft, and rear end suspension). Good luck!
cristoDathird
28
May 30, 2019 08:47 PM
rotor_veux
46
Jun 12, 2018 10:39 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
