greddy FMIC pic request
Old Apr 10, 2003 | 08:24 PM
93BlackFD's Avatar
built my own engine
I need a picture of where the inlet side of the intercooler takes the pipe in....I can't seem to figure out how much of the body to cut away...also, what did you use to cut the body away?
how the hell do you drain the power steering fluid? i just cut the hose and let it drip...
thanks guys
(hoping apneablue or nocab will reply)
Old Apr 10, 2003 | 09:12 PM
coop's Avatar
Here is a picture of my cut away, is that what you are talking about?...
As for the power steering, I just had the right hoses there (needed a new one for the passenger side because the stock one is not long enough) and pulled off the old ones and stuck the new ones on and clamped them down, I lost some PS fluid, but not too much.
93BlackFD's Avatar
built my own engine
bump
Old Apr 10, 2003 | 09:13 PM
coop's Avatar
I used a 4" grinder to 'cut' the metal...make sure you cover turbo intake and IC holes if they are open so you don't get metal chips in them...
93BlackFD's Avatar
built my own engine
ahh, okay cool
that helps me out some, hopefully i'll make more progress tomorrow
my radiator arrives on tuesday, should i just install the stock radiator to hold me over for a while, or would you wait?
Old Apr 10, 2003 | 09:15 PM
coop's Avatar
I put in the new radiator also...I had trouble with the hoses...
If you need any more pics that may help, just say so, and I will post them, they arn't the best, but they may help.
Old Apr 10, 2003 | 09:27 PM
93BlackFD's Avatar
built my own engine
do you have pics of the radiator brackets without the rad in? or perhaps a bottom view?
Old Apr 10, 2003 | 09:56 PM
apneablue's Avatar
Dude, the radiator will be pretty easy to swap out once you get it vertical...
Here are a few pics that will help you along...
The hack job I did on the frame...(Jason at the RX7 store claims you don't have to cut it to make it fit) Frame Cut (I sanded it when I was done)
The amout I trimmed off the bumper to make it fit.
How I cut rebar to make it fit the first time. (not me under the car)
Hope those help...
You can also visit this for some good photos site
Lets see some progress pics!
Old Apr 10, 2003 | 10:03 PM
coop's Avatar
I don't have a pic with the mounting brackets, because mine don't quite fit. I am making new ones in the machine shop at school...
I drilled the holes in the wrong places...so the brackets didn't work...yea, stupid me.
Old Apr 11, 2003 | 11:30 PM
93BlackFD's Avatar
built my own engine
got it mostly together, i'm still concerned about boost leak...these pips fit WAYY too tight for my taste
i feel like i'm bending them to get them to hold, it doesn't help that i don't have the efini y-pipe
gotta trim the front bumper a little more, anyone have close ups of the front bumper/intercooler section? i want to see just how much i need to trim off
thanks guys!!!
Old Apr 11, 2003 | 11:36 PM
apneablue's Avatar
Dude, check out the pic above...Don't touch the trim the top part of the bumper...what you see in the pic is what I trimmed off the bottom and sides...
If you aren't there by tomorrow mid day I will take some pics of mine...
Good luck...
BTW, 1 (ONE) radiator bracket on wrong and it WILL be too tight for the pipes to fit properly...I had to flip around my passenger side bracket cuz I had it on wrong and it made a world of difference...Anyway, like I said...Good luck
Old Apr 11, 2003 | 11:40 PM
93BlackFD's Avatar
built my own engine
i left the radiator loose while i fit the pipes in, and then i pryed it into position while i bolted it down
i'm just not satisfied with the fitment, i will take a wack at it tomorrow
SakeBomb Garage
Oct 9, 2015 10:05 PM
