Help! Failed smog
Old Apr 10, 2003 | 02:03 PM
Alvin's Avatar
Help! Failed smog
Took the car in for it's smog check and it failed. It's a 84 GSL stock with auto trans. The CO was double the allowable amount, but the HC and NO were both within allowable limits by large amounts. Anyone have any ideas how I can get the CO down? Where I live in central calif. we have smog 2 and they put it on the dyno, the CO measured 1.47 at 15mph and 1.20 at 25mph, the limits are .89 and .69. The tech said it most likely is the carb but since RX7s are very rare he's not sure.
Old Apr 10, 2003 | 02:18 PM
Metallic_rock's Avatar
Ride 'n Style
try giving it a tune up. new cap, rotor, plugs, wires, and run 92 octane. worked for me when I was in cali
Old Apr 10, 2003 | 02:40 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Take a standard heater hose and bypass the ACV and run the air pump straight to the cat.
9 times outta 10 it's your ACV messing up.
And then when you leave hook it back to the way it was. I'm sure it'll pass a visual as well.
Worked for me..
Old Apr 11, 2003 | 01:55 AM
Alvin's Avatar
Thanks guys, I'll give her a tune up and I'll try the ACV trick. Would it be worth trying to fix the acv and how much do they cost?
Old Apr 11, 2003 | 03:42 AM
FB II's Avatar
i got one for ya!
Old Apr 11, 2003 | 04:23 AM
TheBigOne's Avatar
Sounds like......
Test your egr. Unless the smog tech passed your egr.
Only other reason I can think of is o2 sensor and cat.
You could retard the timing 10 degress BTDC. You should pass for sure. Just dont tell the smog tech that you did that.
Old Apr 11, 2003 | 08:16 AM
jimtesla's Avatar
A couple other tricks..........
Put a bottle of carb cleaner in the gas tank with about a 1/4 tank to go........make sure the car is hot when you get to the smog station........drive around awhile before you get there..........my old 84 gsl would smoke up the place.........I did this and it always passed.........
Old Apr 11, 2003 | 08:42 AM
Conway's Avatar
Worked for me..
Me too!
Conway
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
Erosangel
Sep 18, 2015 04:06 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
