Problem: Wolf 3D system not working
Old Aug 27, 2001 | 06:18 PM
SPiN Racing's Avatar
Hi,
There is a new wolf forum out there, at the address at the bottom of the e-mail. Another guy is having issues also. I posted a reply to him there.
Things to look for:
Getting RPM while cranking?
Did you make sure you installed the crank trigger correctly? 60' BTDC when dropped in? Did you set cranking timing to 0' and hit it with a timing light to make sure it is at 0?
Is the gap set correctly with the crank trigger? minimum of .001?
Are you getting errors while cranking in the datalogging section for Sig Err?
When cranking did you add cranking fuel rate till it started?
Is the total scale set correctly as listed with the chart in the manual?
Dip Switches set correctly?
Hope these help some..
Scott
Th0m4s
Feb 26, 2019 02:04 AM
Rotospectre
Mar 28, 2018 03:33 PM
