aftermarked temp gauge and stock sender?
Old Apr 6, 2003 | 08:23 AM
David Hu$tlerhoff's Avatar
Question aftermarked temp gauge and stock sender?
I'm planning on putting in an aftermarked temp gauge. i searched the forum and it seems that people do not recommend using the stock temp sender in the rotor housing. it's the most accurate position imo. why is it not a good idea?
Chris
Old Apr 6, 2003 | 12:04 PM
anyone?
Old Apr 6, 2003 | 12:25 PM
jumprdude's Avatar
Because different gauges are calibrated to work with different senders.
The aftermarket gauge is calibrated to use its own sender. Unless you can re-calibrate the gauge to use the stock sender, the gauge could potentially read incorrectly.
Or, you can try to fit the aftermarket sender into the stock sender location. I know some people that have fit the SPA gauge sender in the stock location.
Old Apr 6, 2003 | 01:11 PM
i'm kinda dumb when it comes to such detailed things, i always thought somehow that those senders are built with same "norms", because it always seemed to me like "just buy a temp gauge and a sender and everything is fine."
ok, another question would be, what size (diameter, length etc.) does the stock sender have? maybe i can find an aftermarked one that fits.
Old Apr 6, 2003 | 11:07 PM
alwan16's Avatar
buy an aftermarket gauge and replace the stock sender with this one. then just tap the thermostat housing for the stock sender. i have done this twice with my greddy gauges. the size of the stock sender is M10 0.5" pitch. this is a very fine pitch for an M10. see attachment. i'm not sure what the thread size for other brand's senders are. you might want to ask around.
Old Apr 7, 2003 | 01:24 AM
alwan16's Avatar
I just reviewed my notes and whoops...the pitch is 1.00 not 0.5. It is still an M10m though.
Old Apr 7, 2003 | 01:44 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
While on the subject...
Does anyone have the throttle body coolant line tapped with a sensor?
Old Apr 7, 2003 | 08:48 AM
maxcooper's Avatar
WWFSMD
I have an SPA sender (that came with my SPA gauge) in the stock position. It works great.
-Max
Old Apr 7, 2003 | 01:13 PM
Trout2's Avatar
Senders that are 1/8"NPT, such as SPA and most others, will thread into the stock water temp sensor location.
Jack
Old Apr 7, 2003 | 04:25 PM
guys, thanks again for the great info
immanuel__7
89
Sep 5, 2015 10:23 AM
LMBTG
Aug 15, 2015 01:43 PM
