Vacuum Hose Job... Another Question
Old Apr 6, 2003 | 07:02 AM
HDP's Avatar
HDP
A Fistfull of Dollars!
Exclamation HELP ASAP... Vacuum Hose Replacement
I've nearly completed the hose replacement, but there seems to be 2 hoses I can reach. They go to the bottom ACTUATOR (turbo control). The engine sub-frame is blocking it. How do you remove these 2 hoses?
Old Apr 6, 2003 | 09:44 AM
SilverRX7's Avatar
You should be able to get to them from underneath... I can see them in clear sight... but I have my downpipe off.... do you have the stock DP on?
Old Apr 6, 2003 | 11:52 PM
JONSKI's Avatar
5yr member, joined 2001
Use the "good" color vacuum hose diagram:
I have it hosted here: (right-click -> Save As...)
http://www.rpi.edu/~skrzyj/rx7/93vachosescolor.jpg
Old Apr 7, 2003 | 12:19 AM
DRAG0NEER's Avatar
just gotta find someone with small hands
Old Apr 7, 2003 | 12:30 AM
Fd3BOOST's Avatar
Recovering Milkaholic
You can get to it from the bottom.
Just keep trying, if not then loosen the motor mounts and attach a cherry picker to the uim and hoist brcket and kift the engine a little.
Old Apr 7, 2003 | 01:06 AM
HDP's Avatar
HDP
Well, finally got them off. It took a minute, but I had to use some really long needle nose pliers and an x-acto knife.
Now, one more question that never really got an answer in another post... the aluminum check valve coming from the purge control solenoid (K), is it a one-way check valve? It has a small arrow on it, but I can blow through it both ways.
Old Apr 7, 2003 | 01:22 AM
Fd3BOOST's Avatar
The arrow points to the UIM, But if you went non sequential you wouldnt even need that line anymore
Old Apr 7, 2003 | 01:34 AM
HDP's Avatar
HDP
So.... the arrow points to the manifold... does that mean bad check valve? The gas filter coming from the MAP seansor has an arrow on it, but air flows both ways through it.
This is almost the exact same answer I got before... are you guys picking on me?
Old Apr 7, 2003 | 05:59 AM
Rated R1's Avatar
Oji San
If memory serves, that is a filter not a check valve.
Old Apr 7, 2003 | 10:17 AM
HDP's Avatar
HDP
Well, the pic says check valve.
Old Apr 7, 2003 | 11:24 AM
93BlackFD's Avatar
built my own engine
it's a check valve, mine was bad also
Old Apr 7, 2003 | 11:33 AM
Cihuuy's Avatar
check all the check valve and buy new ones if necessary... u dont want to open everything again..
rotor_veux
Sep 3, 2015 07:10 PM
