difference between part bp and full bp?
Old Apr 3, 2003 | 11:22 PM
hey guys i wanna get a bp dun but i;l be runnin the stock turbo for now wit a big fmic, 3" exhaust, fcd, intake..so my question is whats the difference wit the ports half and full bp? and also gonna port the exhaust like the..the link below is the type of port i'm gonna do on the exhaust what else am i gonna need other then the stuff listed above? will i need a s-afc, and a managent? or jus bigger injectors?
https://www.rx7club.com/forum/showth...hreadid=170114
Old Apr 4, 2003 | 12:22 PM
Rotortuner's Avatar
Undercover
for the engine to actually last more than just a couple thousand miles you need to get a good ECU like a Haltech and yes huge injectors, run like 1600s for the secondarys and like 1200's or something big for the primaries. Its hard to have too much fuel avaliable. You will need a larger fuel pump also and i always beleive in over kill, but new larger fuel line from the tanke and through a high flow fuel filter is a good precaution from running lean. The only difference between a partail bridge and a full bridge is that the partial only has the secondarys bridged where as the full has the primarys brdged also. As far as what you should do, there are a lot of differenet opinions and you will have to make that decision. Oh and ya a stock turbo will NOT be big enough. It will be extremely restrictive. You NEED something bigger, or else you will be very dissapointed in the performance and the reliability.
CJG
Old Apr 6, 2003 | 11:30 PM
thx for the info man it helped alot
Old Apr 6, 2003 | 11:31 PM
but u're sayin even though i only do a partial bp i need to get bigger injectors? won't the TII ones do tha job? for now anyways? i can get 1600 and 1200 cheap but why? for only a partial bp? and also u think i'll need a ecu jus for a partial bp?
befarrer
Microtech
Aug 22, 2015 05:52 PM
Turblown
Aug 14, 2015 04:48 PM
