power window/mirror problem ( HELP HELP )
Old Apr 3, 2003 | 01:34 AM
TJI's Avatar
TJI
hey !!
I have a problem with my passenger side power mirror AND my power window. I was driving home from work and all of sudden it's not working anymore. Driver side is working fine but nothing works for passenger side w/master switch and from the passenger switch. Have anyone had this problem ?? I'm going to check the fuses tomorrow but is there anything else I should look at??
Thanks
Old Apr 3, 2003 | 01:55 AM
TJI's Avatar
TJI
forgot to mention...this was the first time i tried opening the window since December..I had it under the cover during winter time
Old Apr 3, 2003 | 10:22 AM
djantlive's Avatar
Is it both window and mirror broken at the same time? The passenger window switch tends to oxidize and cause bad connection. You can pop the switch out to clean it. I have a spare switch if you need to replace it. Otherwise, just clean the contact.
Old Apr 3, 2003 | 03:11 PM
TJI's Avatar
TJI
Yeah !! both of them dosen't work. It was working fine before but it seems like nothing on the passenger side is working at all. I was thinking maybe it has something to do with the master switch???? ( driver side ) since the power mirror is not working too. I will try cleaning the passenger/driver side connectors tomorrow and see if it will work. But what would cause the Power mirror to fail since the switch is connected to Master switch ??
Thanks
Old Apr 3, 2003 | 06:02 PM
NukeGenius's Avatar
Dim Sum owns you!
If only passenger side not working, did you try switching the little thing under it to "on"? Mine driver one will work, but not passenger when it is on the off position. Sometimes it gets bumped and you dont notice it. Hope that helps, it always seems to be my problem.
Queppa
Nov 18, 2024 03:47 AM
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
