Interesting.. Cryo Intake
Old Apr 1, 2003 | 11:20 PM
Brentis's Avatar
http://www.designengineering.com/cry...ir_intake.html
The CryO²™ Air Intake consists of an aerodynamically design bulb with a cryogenic chamber which is mounted in a 4" segment of air tube. As the air passes over the bulb heat is removed from the air charge resulting in a colder, denser more powerful charge. Dyno testing showed a reduction in intake air temperature of more than 35%. The CryO²™ Air Intake can be used on tubocharged, supercharged or naturally aspirated applications. Multiple units can be used for colder results. Installs in minutes and comes with silicone connection sleeve, hose clamps and connection/vent hose.
Old Apr 1, 2003 | 11:33 PM
ttb's Avatar
ttb
No Cup Holder Racing
i'm not a big fan of things that you have to refill for it to work.
Old Apr 1, 2003 | 11:55 PM
93blackrx's Avatar
how do you raise the "bs flag"?
Old Apr 1, 2003 | 11:57 PM
93blackrx's Avatar
Got it
Old Apr 2, 2003 | 12:04 AM
Zoomspeed's Avatar
Won't that dot the same thing, as the N-tercooler from nitrious express, except it looks like it woudn't do it as well.
Old Apr 2, 2003 | 12:42 AM
EviLPeNeviL's Avatar
Can't live without boost.
Yeah, intercooler coolers are cool...........
Old Apr 2, 2003 | 12:52 AM
dznutzuk's Avatar
Uncontrollable drifter
I think it's like this
Old Apr 2, 2003 | 07:44 AM
Brentis's Avatar
So they say it is an entire linked system. You use the sprayer as the last link since it is the link that releases it to the atmosphere. Here is the sprayer..
http://www.designengineering.com/cry...r_sprayer.html
Old Apr 2, 2003 | 08:05 AM
911GT2's Avatar
The Power of 1.3
Liquid CO2+underhood temps of FD = KABOOM?
Old Apr 2, 2003 | 08:18 AM
vudoodoodoo's Avatar
WTF.
Old Apr 2, 2003 | 09:59 AM
paw140's Avatar
CO2 is not flammible, it is actually used in fire extinguishers. What have you been smoking?
Old Apr 2, 2003 | 10:00 AM
paw140's Avatar
It doesn't sound like bs to me. Why do guys think this is bs?
Old Apr 2, 2003 | 10:23 AM
Brentis's Avatar
I think the best place to put it would be just before the TB. Hell - rig it to use the throttle body coolant lines..
Old Apr 2, 2003 | 10:25 AM
Brentis's Avatar
I don't like windshield wipers or gasoline powered cars for that matter either...
I know what you mean though... if only there was a CO2 and NO2 station next to gas stations..
Old Apr 4, 2003 | 12:13 AM
If you use the throttle body coolant lines you might have AWS problems?
Old Apr 4, 2003 | 12:59 AM
poss's Avatar
Slower Traffic Keep Right
I think he was refering to the tank being mounted in the engine bay....CO2 tanks + underhood temps = boom
i don't think it's bs, but i sure as hell would never buy one.
Old Apr 4, 2003 | 10:08 AM
Newbie
Why wouldn't it work, it's essentially like a nitrous intake fogger kit but instead CO2 is used. If it helps my air molecules become more densly packed I ain't give a ****.
Old Apr 4, 2003 | 12:00 PM
93BlackFD's Avatar
built my own engine
co2 gets cold when you release it...or go from high pressure to low pressure
so unless they're venting it into your engine, which could go into your intake, i don't see how theyr'e getting it cold
Old Apr 4, 2003 | 12:09 PM
poss's Avatar
I think it works similarly to the NX N-ter cooler.
Old Apr 4, 2003 | 12:28 PM
paw140's Avatar
The way I understood it, you hook that thing up to your intank tract, and it is basically a heat exchanger. The CO2 makes *something* in the air stream cold and cools down the air charge. I'm not sure, as the site is not very clear, but I don't think it injects CO2 into the engine.
