What lowering springs do you have??
Old Aug 24, 2001 | 10:58 AM
Ryde _Or_Die's Avatar
I was just wonderin what kind of springs you have and how much they lower your car? Also what are your opinions on the ryde? Thanks.
Chris
Old Aug 24, 2001 | 11:05 AM
JaySpec7's Avatar
Eibach Pro Kit w/ APEXi T-Max Shocks
Rides really well on the street.. haven't had track time on em yet... so far so good
Old Aug 24, 2001 | 11:51 AM
rxrx7's Avatar
Eibach Pro-Kits
Old Aug 24, 2001 | 12:20 PM
How much did they lower your car and do you have custom rims? If so, what size? Thanks.
Old Aug 24, 2001 | 01:20 PM
springs
have ST BOESO dual spring coil overs on front(Ebachs springs) just put on a set of Ground Controls on last night in the rear. lowered the car about an inch to a inch and half. Running 18 all the way around. setting ground to wheel well 24" in front and 25" in rear. so far no problems.
Old Aug 24, 2001 | 01:32 PM
FDMatt's Avatar
I have Bilstein struts and Grex 1" lowering springs. I have 17" Blitz type 03's with 235 45 in the front and 245 45 in rear. Looks and rides good.
matt
94 RX7
336hp & 272 lbs/ft of trq.
Old Aug 25, 2001 | 02:33 AM
Driftfc3s's Avatar
Final Form
Tanabe Super Down Precedeo Springs. Tokico Gas shocks. 2" drop. Too damn low!
Old Aug 25, 2001 | 04:08 PM
Trout's Avatar
I used to have the Racing Beat springs with Tokico shocks. Ride height measured ground to top of wheel well was 25 in. rear and 24-1/2 in. front. Stock ride height was at least 26 in., the RB springs lowered the car alot. I got rid of this set-up a few months ago because the RB springs were way too soft for that low of a ride height. I had prolems with bottoming alot and the front tires (245/45/16) rubbing on the top of the plastic fender liner. I was also hitting the bump stops in long sweeping turns.
Now I have the M2/AD coil overs with 550/450 lb/in Eibach ERS. They're adjusted to 25 in. ride height all around. No more bottoming and much better control, especially coming out of corners. Jack
Old Aug 25, 2001 | 05:20 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I have racing beat springs with bilistein shocks.
Old Aug 29, 2001 | 10:06 AM
ApexRX7's Avatar
H&R springs with Apex T-max shocks lowers it about 1 1/2 inches- which is just rigfht for me
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
