bad feeling I forgot to put in the pilot bearing
hey guys I have this really bad feeling that I forgot to put the pilot bearing in my new motor. I havent started the thing yet, so is there anyway to check if the thing is in or not with out removing the engine?
look around your work area? see it on the floor, in a box, on a table ect....
i dont know if there is a way to tell if its in there a guru will tell you that. all i can say is look around. if you fin it some where odds are its not where it should be.
good luck
good luck
Re: bad feeling I forgot to put in the pilot bearing
Re: Re: bad feeling I forgot to put in the pilot bearing
Originally posted by SoRRoW
Yeah...remove the tranny
but yea. you will have to take that off.
also look around
GrossPolluter
Aug 15, 2015 10:32 PM
