troubleshooting A/C
Old Mar 27, 2003 | 04:03 PM
93BlackFD's Avatar
built my own engine
troubleshooting A/C
how do I tell if my a/c compressor is engaging?
I guess I am going to wait until the car cools down, so then when I engage the a/c it should kick the clutch on
my PFC shows A/C is on, but i think that's only an indicator of the a/c switch position
am i right?
Old Mar 27, 2003 | 07:31 PM
93BlackFD's Avatar
built my own engine
stupid compressor isn't engaging
great
Old Mar 27, 2003 | 07:50 PM
Mahjik's Avatar
Mr. Links
Have you checked your freon level? If it gets too low, it disables the compressor from engaging.
Old Mar 27, 2003 | 07:53 PM
93BlackFD's Avatar
built my own engine
heh, sure did
i bought a freon level checker, and it says to let the car idle for 5mins- done, and then put the gauge on the low pressure side, so i pulled the blue cap off (the one on the larger diameter hose) and pushed it down, it shot the needle out
am i doing something wrong?
Old Mar 27, 2003 | 10:18 PM
Mahjik's Avatar
Mr. Links
Originally posted by 93BlackFD
heh, sure did
Unfortunately, I'm not sure. So, this will at least bump you back up to the top so someone else can chime in.
Also make sure to check the fuses (if you already haven't).
Old Mar 27, 2003 | 10:21 PM
93BlackFD's Avatar
built my own engine
i do have the powerFC...so that might be the issue, but i'd like to check out all other possibilities
Old Mar 27, 2003 | 10:46 PM
seabass's Avatar
put the stock ecu back in to rule out the PFC.
if it works with stock ecu then search for the AC fix(work around) posted by chuck.
PFC and AC=hot air in some cars.
Coochas
44
Nov 5, 2019 11:08 PM
93FD510
Oct 1, 2015 02:00 PM
Turblown
Sep 30, 2015 05:58 PM
