Need help with a boost problem. Please
Old Mar 26, 2003 | 09:24 PM
wicked sol's Avatar
Well I just picked up a 94 a week ago and this is my first 7 so I just need a few ideas where to look or what it might be. I don't know the names or what parts could even cause this to use search yet. Sorry.
The problem is that sometimes I don't have any boost and sometimes I do. It seems to happen more often when I jump on the throttle real hard or when I'm driving mote aggressive. I don't have a boost gauge yet so I don't know if I'm getting any boost or just very little. When this is happening and I let off the throttle I can hear the bov. I bought the car knowing of this problem and the guy said he had it to a shop and they replaced a valve that could be causing it but he doesn't know what valve it was. I don't think it was the bov. Just doesn't look new.
Thanks for any help.
Old Mar 26, 2003 | 09:49 PM
twinturborx7pete's Avatar
Juris Doctor
hook a boost gauge up to it and then come back... you should be seeing 10-8-10 boost pattern on the car if it is STOCK.
Old Apr 10, 2003 | 04:06 PM
wicked sol's Avatar
ok well I finally got the gauge installed and I'm seeing a normal boost patteren when I stepon the gas lightly but if I hammer it in any gear I see nothing. The gauge just stays at 0. I also hear a strange sound when this happens when I let off the gas. Its not the normal bov sound but it kinda sounds like air I guess.
Could it be the bov sticking open?
Old Apr 10, 2003 | 04:12 PM
milkman2k52's Avatar
check all of the hoses on the intake track. Just to be sure it's not something simple.....
Old Apr 10, 2003 | 05:23 PM
LAracer's Avatar
This *might* be your turbo control actuator (TCA) sticking. I'm not exactly sure what the symtoms are when the TCA sticks, but I'm sure someone will correct me if I'm way off. You might want to get a vacuum pump ($30, autozone) and check all the actuators. Also check the vacuum hoses, solenoids, and check-valves. It gets complicated pretty quick if you're new, but it's not impossible to learn how it all works. This place should help...
http://www.autosportracetech.com/RX-7/rx7stuff.htm
Microtech
Nov 21, 2015 10:20 AM
Bauer778
Nov 4, 2015 04:42 PM
vmerino
Sep 5, 2015 11:26 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
