Error codes 30, 33 and 39!
Old Mar 26, 2003 | 03:26 PM
cover8's Avatar
Well getting cel codes 30 split air bypass
33 port air bypass
39 relief 2
Removed acv and egr with 93 ecu did not get codes...now with pettit (not sure which year) ecu I am now getting cel codes Anyway, I can find the egr connector and use a 1/2 watt 330ohm connector but what can be done about the 3 prong connectors for the acv? Will I have to reconnect the acv to the clips to remove the codes but not connect to the lim?
Will these codes put the car in "limp" mode?
Damn if it isn't one thing, it is another!!!
Old Mar 27, 2003 | 07:58 AM
cover8's Avatar
bizzump
Old Mar 27, 2003 | 08:26 AM
JONSKI's Avatar
5yr member, joined 2001
I don't see why ACV problems would cause limp mode. Maybe Pettit can tell you what's going on.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
ZacMan
Sep 19, 2015 09:20 PM
