questions about aftermarket fuel pump and a pic of my setup
Old Mar 25, 2003 | 11:30 PM
Question questions about aftermarket fuel pump and a pic of my setup
i bought the fuel upgrade from rx7.com which consided of the 1600cc injectors, sx regulator, and the rp performance pump i couldnt get any fuel pressure out of the rp pump so i put my stocker back in and i got fuel pressure and i was able to adjust the pressure which i wasnt able to do with the rp pump ive heard that u have to rewire and relay it to get stonger current is this true anyone else had this problem or do u think the pump is bad any info is helpful thanks eric
Old Mar 26, 2003 | 01:38 AM
TonyTurboII's Avatar
Glock Lover
remember, its basically just a motor. Maybe the polarity was reversed. If youre sure it wasnt, id say its a bad pump.
Old Mar 26, 2003 | 02:26 AM
Astro's Avatar
ya, because the RP pump is just another denso pump (like the factory) but higher flowing.
I think its mk4 supra twin turbo pump.
Old Mar 27, 2003 | 10:14 AM
1point3liter's Avatar
Twin Turbo LSX
This may be a little off topic, but are you planning on running the greddy stock mount?
Old Mar 27, 2003 | 12:20 PM
Trout2's Avatar
The RP pump is plug and play, no re-wiring involved. I've used one for a year with no problems. While my car has been sitting I had it flow tested at Kinsler with good results.
Jack
alphawolff
Nov 17, 2015 05:57 PM
