Lighting problem
Old Mar 22, 2003 | 01:07 AM
yayo420's Avatar
Lighting problem
Ok, My little idiot light that says STOP LIGHT stays on......All my lights work fine....BUT I have noticed that when I have my foot on the brake all my parking lights are on (ie: front corners) What is causing this?????? I forgot, my instrument panel also lights up when I put my foot on the brake
Old Mar 22, 2003 | 01:37 AM
Keaponlaffen's Avatar
Bad ground... I'd bet you there's at least an 80% chance it's that...
My '79's front signal lights turned on when I hit the brakes, and backup lights when I signaled, and **** like that... turned out the ground for the rear tail lights in the hatch area was disconnected... re-connected it, and voila, everything worked normal again...
Old Mar 22, 2003 | 01:41 AM
yayo420's Avatar
Is the ground hooked to the actual latch?? if so PROBLEM SOLVED!!
Old Mar 22, 2003 | 01:49 AM
I believe mine was hooked to the lisence plate light bolt('79), so being hooked to the latch would make sense on a later-model car? try it and find out haha...
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
fastsaab
Aug 19, 2015 11:42 AM
gtcd
30
Aug 19, 2015 02:44 AM
