Kow many pistons does a 1 gen RX-7 have
Old Mar 21, 2003 | 03:16 PM
PaulFitzwarryne's Avatar
Apprentice Guru
I would be grateful if someone could tell me how many pistons an 1985 RX-7 has.
Old Mar 21, 2003 | 03:18 PM
abeomid's Avatar
I sure hope you are joking with 650 posts you have on a RX-7 forum???
For ur info (if you are actually ignorant enough) first gen has a Rotary Engine. It has two rotors. No pistons
Old Mar 21, 2003 | 03:55 PM
actually i believe the brake calipers have 2 pistons..........but other than that
*cough* POSTWHORE *cough*
Old Mar 21, 2003 | 03:57 PM
Dom's Avatar
Dom
callin' tokyo
One at each corner,....!?
Old Mar 21, 2003 | 04:05 PM
REVHED's Avatar
Hunting Skylines
7... clutch slave, clutch master, brake master and calipers.
Old Mar 21, 2003 | 04:06 PM
inittab's Avatar
I read your email
Re: Kow many pistons does a 1 gen RX-7 have
Good one Paul!
Old Mar 21, 2003 | 04:20 PM
Apprentice Guru
inittab-trivia night question!
revhed- thanks we are getting there
Old Mar 21, 2003 | 04:36 PM
diabolical1's Avatar
okay ... i'll bite, too
9 ... if you add the hatch struts
how's that?
Old Mar 21, 2003 | 05:46 PM
1st to 3rd's Avatar
If the hatch struts count, then I can think of 17. Ones mentioned above, front struts, rear shocks, and the 2 front & 2 rear bumper stocks.
Old Mar 21, 2003 | 05:50 PM
MikeLMR's Avatar
'Last Minute' Rallying
what about the oil metering pump , that has a piston
Old Mar 21, 2003 | 06:01 PM
82transam's Avatar
Never Follow
dashpot has a little piston in it
Old Mar 21, 2003 | 06:06 PM
NanaimoRx-7's Avatar
How about we change the question to how many cylinders does and Rx-7 have? That way we can add door locks, and other misc. junk. Doesn't the OMP have a small pin sized piston too. Jeez, we're going to be at 36 in no time.
Old Mar 21, 2003 | 06:44 PM
gamble302's Avatar
roadkill hats rock
define piston please..... ok, what is its origin? hrmmmmmmm
P I S T O N, piston
Old Mar 21, 2003 | 06:47 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
SAME AS THE NUMBER OF VALVES IT HAS
Old Mar 21, 2003 | 06:53 PM
gamble302's Avatar
roadkill hats rock
so not true, your tires have valves, but no pistons, unless you count the valve core plunger. some game this is, hey everyone think of ever single itty bitty part on a 1st gen and figure out how many pistons there are
Old Mar 21, 2003 | 08:05 PM
BRealistic's Avatar
Are there pistons in the locks?????
Old Mar 21, 2003 | 09:43 PM
Pele's Avatar
Right near Malloy
Actually, the RX-7 has dual/split braking system... The master cylinder is a single cylinder, but two pistons...
Two hydraulic systems, one for front-left and right-rear; One for the front-right; left-rear brakes... In the event of a hydraulic failure, you still have some braking ability.
Old Mar 21, 2003 | 09:51 PM
82transam's Avatar
Never Follow
really? hmmm, seems dear old dad was right afterall....
Old Mar 21, 2003 | 10:09 PM
Pele's Avatar
Right near Malloy
eh?
I have diagrams from my text book from "Basic Braking systems"... A course I took while working for a shop.
Hey... Get paid to sit around and discuss brakes... I'll do it!
Old Mar 21, 2003 | 10:23 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
The stock fuel pump has an electromagnetically operated piston in it.
The float bowl solenoid is essentially a piston that closes off the vent when the car is shut off.
Old Mar 21, 2003 | 11:14 PM
82transam's Avatar
Never Follow
eh?
My dad and I had a discussion about the brakes a long time ago and it ended up with both of us getting annoyed and not really solving anything, if what you say is right then he was correct.
Old Mar 22, 2003 | 12:13 AM
nization's Avatar
ROFLMAO! Great trivia, man. But it's about the RX-7....is that really trivial?.....
Old Mar 22, 2003 | 12:19 AM
rotor vs. piston's Avatar
Function > Form
For those of you that still have AC, you need to add the pistons in the compressor.
Old Mar 22, 2003 | 02:07 AM
moremazda's Avatar
Gone Race'n
Deceleration valve, Roll over check valve, coolant valve on the heater core, air ducting valves in the HVAC system, air control valve, thermostat.
Am I missing any??
Ryan
Old Mar 22, 2003 | 02:15 AM
unreality's Avatar
Always broken.
ah crap guys, think about it, most solenoids act as pistons.
just think about the rat's nest.
S, GS, GSL, or GSL-SE?
5 speed? Automatic?
You could count the pistons inside the valve body of the automatic transmission...
