How to remove the rear-view mirror?
Old Mar 21, 2003 | 12:58 PM
Aico's Avatar
It doesn't say in The Haynes Manual
How do you remove it?
Old Mar 21, 2003 | 03:13 PM
cveklund's Avatar
I think I read a while back that you take the light lense off and take out the two screws to remove it.
Chris
Old Mar 21, 2003 | 05:56 PM
sweetege's Avatar
bzzzzzzzzzzzzz
if you want a pic i can get one?
Old Mar 21, 2003 | 07:13 PM
pratch's Avatar
Mazspeed.com
Yup. remove the light lens, you'll see two screws. Pull back a little bit and you'll find two wires which you can disconnect. It should come right out after that.
Old Mar 22, 2003 | 06:09 AM
Aico's Avatar
I've removed the light lens and I see the 2 screws. But I also saw that the lightbulb is part of the rear-view mirror?
Do I lose the lightbulb if I would remove the mirror? (I didn't had any tools so I couldn't check for myself)
Old Mar 22, 2003 | 07:52 AM
pratch's Avatar
Mazspeed.com
If you removed the mirror (check with your country's regulations regarding that) it shouldn't effect anything. Of course, it has been a few months since I had mine out... But I'm pretty sure you could do it if you wanted to.
Old Mar 22, 2003 | 11:30 AM
bliffle's Avatar
The rearview mirror is too obtrusive for me, so I cut it off with a cutoff wheel in my dreml, close to the top, and added an aftermarket mirror glued to the windshield down low. Much better for a tall guy. Did it on both cars.
B
Old Mar 22, 2003 | 12:51 PM
Manntis's Avatar
add to cart
It's easier to remove the whole roof console assembly, then remove the mirror post from the assembly, and replace the assembly sans mirror
