Anyone of you guys use a COSTCO battery in your FD?
Old Mar 20, 2003 | 10:32 PM
doogie's Avatar
Smile Anyone of you guys use a COSTCO battery in your FD?
Just wondering if they are any good. I know they are cheap, but did you have any issues with them. Need a new one soon. What size did you get and how much and how long have you had it?
Old Mar 20, 2003 | 11:19 PM
skunks's Avatar
I'm a CF and poop smith
The only issue is that you might need to extend the positive connector since the ones I buy (the grey ones) seem to have the battery terminal a little too close to the middle. Other then that, they seem to be great. I never had one die on me so far and they have great CCA.
Old Mar 20, 2003 | 11:27 PM
GoRacer's Avatar
Speed Mach Go Go Go
Since they are water filled, you should have the stock batter box to cool it down. I did not and the acid corroded parts under it. Spend the extra money on a sealed one or a gel filled better yet.
Old Mar 20, 2003 | 11:41 PM
skunks's Avatar
Yes a sealed battery would be better but he is asking about costco batteries and in a pinch, they will work As for the other issue about when batteries heat up, they do give you a bit more charge, although since your alternator is running, this is kind of a mute point . Also, you are right where they may boil over and corrode the underneath, although it has never happened to me.
Old Mar 21, 2003 | 01:16 AM
I just got a Costco battery today for my fd they have Optima red, yellow and blue there, I got the blue one cause imma gonna use it in the rear bins and the blue ones got the double terminals on the top
Old Mar 21, 2003 | 09:41 AM
frank69m's Avatar
Not yet. I'm looking at getting one also. Not sure if I should put a Die Hard though.
Old Mar 21, 2003 | 09:53 AM
HAHAHA HELL YEAH! i just put mine in 3 days ago because that interstate battery was a piece of Shiet! but yeah i got a kirkland battery from costco and it works perfectly!
Old Mar 21, 2003 | 09:57 AM
Alpha-7's Avatar
Costco oh my god.........
Old Mar 21, 2003 | 11:13 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
get a 51r size battery......saves you 10 lbs
Old Mar 21, 2003 | 04:35 PM
doogie's Avatar
RX7_rage, what brands sell the 51r...Does CostCo Kirkland batteries have that size and do you need a kit so that it fits? And what was wrong with Interstate?
Old Mar 22, 2003 | 01:55 AM
Nathan Kwok's Avatar
I'm using a Kirkland (Costco) battery right now (standard size). It works, fits normally, has lasted for about 2 years now, what can I say?
Old Mar 22, 2003 | 03:31 AM
insomniac's Avatar
Costco carries Optima batteries? How much?
Old Mar 22, 2003 | 03:49 AM
Lunar7's Avatar
My car had a Costco/Kirkland battery when I bought it. It never leaked or corroded.
It was still going strong when I decided to swap it for an AC Delco 51R on a TurboJeff batterey tray.
I think the Costco/Kirkland (made by Johnson Controls) is a much better battery than the Exide or GNB crap you get from the auto parts chains.
In fact I would take a Costco/Kirkland over a Fry Hard or Shiterstate any day.
For a conventional type batterey, AC Delco is all I would consider.
They are hard to find & expensive but excellent quality.
Of course a Hawker Energy Odyssey PC1200MJ is about the best you can get, but for huge $$.
For low bucks the Costco/Kirkland batterey is excellent.
To get better you need to spend more than twice the money.
Old Mar 22, 2003 | 03:56 AM
RX7 RAGE's Avatar
Top Answer: 1
I got my 51r battery from sears and you don't need a kit to make it work.
Old Mar 22, 2003 | 04:53 AM
was around 216 cdn I think ,for the blue top
Old Mar 22, 2003 | 09:44 AM
frank69m's Avatar
Does the Costco/Kirkland battery need a modified tray or you can you use the stock ones?
Old Mar 22, 2003 | 11:12 AM
93blackrx's Avatar
costco is the ****. I got my dry cell (red top) battery from there, only thing is I had to buy it in a pack of 12.
Matt
Old Mar 22, 2003 | 11:37 AM
Lunar7's Avatar
Costco/Kirkland Item# 207140 fits perfectly.
A good choice for the money.
However, I do recommend you look into an AC Delco Professional 7 Year batterey 24R7YR.
http://www.acdelco.com/html/pi_batt_prof.htm
At $90, they are the best sub $100 batterey worth the extra money.
Old Mar 22, 2003 | 05:30 PM
RX7Elmo's Avatar
i've run a costco batter in my FD. it's the 51 size. I believe it's the exact same one used in civics and integras woohoo.
It was only 39 bucks and has a 2 year warrenty
Danny
Old Mar 24, 2003 | 09:52 AM
doogie's Avatar
Cool. Thanks everyone. Costco here I come. Looks like Interstate is about double the price also.
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
