the LAST problem w/ me rex, finally
Old Mar 20, 2003 | 01:48 PM
i have fixed many things since i bought the car, mostly small, but the last thing left, which just started is: a wonderful oil leak somewhere on the front of the engine, mybe towrds the passenger side. its is a slow leak, becasue i wouldn't even notice it IF the freakin oil wasn't getting on the exhust manifold (only an aftermarket oone id called a "header", right?) and causeing that to burn off and making a crap load of smoke. i look like an *** when i pull up to someones house, park, get out, and 2sec later a bunch of smoke is pouring out form underneath my hood. i recently did an oil change, but i am having trouble getting to teh area to get a closer llok. OMP mybe? any ideas would be GREAT!
Old Mar 20, 2003 | 01:52 PM
DONNA's Avatar
weird, thats what mine does too, im gonna look into rebuilding the omp this weekend,,,later...
AdrenalifeRX7's Avatar
Are you gonna shift?!
Yeah I'm guessing it's the OMP. Mine did the same thing. Strange cuz the mechanical OMP's have a very rare failure rate. I plugged my OMP lines and I run full premix now. Clean up the area of the leak a bit and check it again.
Old Mar 20, 2003 | 02:13 PM
how hard is it to replace the OMP, there isn't much room down there to work...
Old Mar 20, 2003 | 07:34 PM
inittab's Avatar
I read your email
It's not that hard to remove or work on. I first removed my air-pump and that gave me plenty of room to work. Rebuilding the pump is pretty easy too. Give Lowe Performance a call and order your $20 kit, get yourself some brake cleaner to clean the parts and your all set.
Old Mar 20, 2003 | 08:23 PM
damn hippies
wait..you can take the omp out and run premix?...what kinda oil would be used with the gas...2 cycle or 10w something?
Old Mar 20, 2003 | 08:25 PM
OtakuRX's Avatar
The Rotorheaded Geek
2cycle, that way it mixes properly and doesn't clog your fuel filter or anything. Also burns cleaner.
Old Mar 20, 2003 | 08:33 PM
damn hippies
and smellls nice too hu?
Old Mar 21, 2003 | 01:01 AM
brownmound's Avatar
Anytime baby!
Right on...and here is some help for ya as I just did this.
http://www.godofredo.com/mound/3-11-03.html
Right on
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
