Hose Question - near turbo oil lines
Old Mar 19, 2003 | 04:43 AM
poss's Avatar
Slower Traffic Keep Right
there is a hard pipe connected to the oil line that feeds the turbo. I don't remember where it goes to. it's right next to the passenger side of the thermostat housing.
Can someone help me?
TIA
Old Mar 19, 2003 | 05:49 AM
TorqmasterD's Avatar
Newbie
It goes to a banjo bolt that is basically right below the oil fill cap. on the front housing
Old Mar 19, 2003 | 12:03 PM
poss's Avatar
where does the other end go?
Old Mar 19, 2003 | 12:05 PM
dubulup's Avatar
development
the turbo inlet.
Old Mar 19, 2003 | 02:10 PM
duboisr's Avatar
One end goes to the oil filler unit ( a nipple that points down ) ,the other end goes to the pri turbo intake elbow
Old Mar 19, 2003 | 02:26 PM
poss's Avatar
That's what I thought, but when the engine was on the engine stand, and I rotated it, it started dripping oil. but it makes sense if it connects to the oil filler neck.
thanks guys.
Old Mar 19, 2003 | 03:18 PM
gohorns's Avatar
I would also change the gaskets to avoid leaking. There is one on each end.
Old Mar 19, 2003 | 07:26 PM
duboisr's Avatar
what gasket , he is asking about a vacuum line next to the oil line. the oil line has two copper o -rings, gaskets if you like , the vacuum line has no gaskets.
Old Mar 21, 2003 | 03:17 AM
you may also want to make sure that the hose you are fooling with is not the cooland hose that feeds the throttle body which is also next to the thermostat behind the air pump.
Old Mar 21, 2003 | 05:23 AM
Haggard's Avatar
LOL banjos use copper washers not orings.
duboisr called it..
the trottle body coolant hose can be removed you dont need it anyway.
BLK 93
Aug 19, 2015 03:47 AM
pzr2
Aug 15, 2015 08:29 PM
