aftermarket stock size IC DUCT?
Old Mar 18, 2003 | 10:56 PM
ZeroBanger's Avatar
Anyone sell one? I saw the ad from the guy on the forum that makes the c/f hoods and ic duct, but the duct is bigger than stock. I have a Blitz SMIC and my IC duct has the hole for where the intake used to be and well...duct tape is not appealing.
so ...does anyone sell one?
Old Mar 19, 2003 | 12:35 AM
ttb's Avatar
ttb
No Cup Holder Racing
you talking about something like this?
you can get that duct for 150.
Old Mar 19, 2003 | 09:43 AM
ZeroBanger's Avatar
COOL, where can I get it?
Old Mar 19, 2003 | 11:38 AM
Mahjik's Avatar
Mr. Links
Arrow
http://www.pfsupercars.com/mods/rx7/...ntercooler.htm
Old Mar 19, 2003 | 11:49 AM
ZeroBanger's Avatar
Does PFS still sell used stuff and pretend its new? I never order from them before and try to avoid. If they are the only vender, well I'll buy it then. Thanks
Old Mar 19, 2003 | 11:58 AM
PVerdieck's Avatar
Go post in the parts section, there has to be someone that upgraded that has the old one.
Old Mar 19, 2003 | 12:02 PM
1stand3rd's Avatar
You can also use the duct for the Pettit Coolcharge II SMIC.
Old Mar 19, 2003 | 12:05 PM
ZeroBanger's Avatar
wow thanks everyone for the help.
Mahjik's Avatar
Mr. Links
I don't think Pettit sells their duct separately from their IC kit.
Old Mar 19, 2003 | 12:26 PM
redrotorR1's Avatar
LS6 Convert
They do. I bought one from Pettit for $100. However, it is not the stock size. The side facing the IC is quite a bit larger than the stock duct. It will take some cutting and sanding to make it mate up properly.
Old Mar 19, 2003 | 12:32 PM
Mahjik's Avatar
Mr. Links
Cool, thanks. I took a look at their site and didn't see it listed separately. I guess it's one of those "you gotta call 'em" things.
Old Mar 19, 2003 | 12:51 PM
ZeroBanger's Avatar
cool, I have a Blitz SMIC, so it will probably work. what is the quality? is it better than the stock one?
Old Mar 19, 2003 | 02:38 PM
redrotorR1's Avatar
LS6 Convert
Mahjik, you're on the ball there ... I had to call them direct to get it.
Zerobanger, check out this link:
http://www.rx7turboturbo.com/robrobinette/ic_duct.htm
Mine looks exactly like the duct that Rob has in his writeup. Quality is good. Definitely better than the stock one. But, you will lose the routing of air around the condenser. (Not a big deal, IMO.) If you go this route, make sure you do multiple fitments of the duct to the IC as you are cutting and sanding it down. Rob's writeup makes it sound really easy ... IC, pipes, and the duct took me an entire afternoon.
Old Mar 19, 2003 | 06:48 PM
maxcooper's Avatar
WWFSMD
Consider adding a rubber seal around the edge, to keep all the air going through the IC core. If it is easier for the air to go out the sides, some of it will.
http://www.mcmaster.com/ and probably many other places (Home Depot, auto parts store) probably have something you could use.
-Max
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
