do new mazda turbos have the boost pills built in , or in the lines
as the subject states, im having some secondary boost issues, and I pulled off the lines that are supposed to have the pills in them but there are none, but I dont have primary troubles. I just figured that the new turbos had them built in since all 95s were like that. anyone know for sure?
scott
scott
Originally posted by rynberg
There aren't pills on 95s, the nipples are the restrictors. To change to a larger pill = boring out the holes on the nipples. It's a better idea to just use a boost controller or ecu to control boost on later FDs.
yeah i had the same problem. all you have to do is get under the car and pull the little elbow off that has the prespool and wastegate nipples on them and simply drill them out. then hook up two manuel valves or something to get the boost where you want it and to control the spike.
Frisky Arab
13
Aug 18, 2015 05:30 PM
