popping exhaust?
Old Mar 18, 2003 | 09:37 AM
rybrx7's Avatar
popping exhaust?
havent had my seven long so not sure if its meant to do this, was going down the motorway and as i put my foot down and went through the gears the exhaust kept popping a lot, and when it popped the car felt like it was stuttering, like power was going on off on off, what causes this??
Old Mar 18, 2003 | 09:38 AM
meddle's Avatar
try plugs and wires
Old Mar 18, 2003 | 09:47 AM
rybrx7's Avatar
its due to get a service soon so i'll get new spark plugs fitted then, hope that sorts it
Old Mar 18, 2003 | 09:52 AM
Street King's Avatar
*** Bless Texas!
New plugs and/or fuel filter.
Old Mar 18, 2003 | 12:58 PM
rybrx7's Avatar
if i have a full system exhaust could it be the fuel is running lean and its to do with the detonation??? its coming from the rear of the car though not the engine, but that was a suggestion from another board.
its the apexi n1 exhaust if any1 has one have they experienced this???
Old Mar 18, 2003 | 01:54 PM
ttpowerd's Avatar
HARRRRRRRRR
yes, you are running too rich and the excess fuel not burned up in the combustion process is getting pushed out the exhaust. Happens more on cars with catalytic converters but mine pops a little too.
Old Mar 18, 2003 | 04:41 PM
rybrx7's Avatar
assuming i change the plugs and the prob doesnt go away what do you guys suggest? a power fc?
Old Mar 18, 2003 | 04:54 PM
Mahjik's Avatar
Mr. Links
Take one step at a time. Do as everyone suggested above (normal maintanence):
1. Change oil/filter
2. Change fuel filter
3. Flush coolant
4. Change spark plugs and wires
5. Change O2 sensor
That will give you a good basis to start with. After that, if you are still having problems you can diagnose them from there.
rgordon1979
40
Mar 15, 2022 12:04 PM
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
