center rear view mirror is loose
Old Mar 18, 2003 | 08:56 AM
overkill's Avatar
my center view mirror is getting loose. How is it attached so that I can tighten it back up??
Old Mar 18, 2003 | 09:15 AM
MastaCow's Avatar
There's a screw that holds the assembly onto a plate. Unscrew the thing, and you'll find a plate nderneath with one or two screws (can't remember)
Tighten those screws first, then reassemble the mirror to the plate.
I spent about 3 months trying to tighten the first screw in vain before i said F'it and pulled it apart, just to realize how dumb i was.
Old Mar 18, 2003 | 09:29 AM
vudoodoodoo's Avatar
Mine came loose and actually fell off while driving.
I just tightened the screws on that metal plate thing and stuck the mirror back on.
Old Mar 18, 2003 | 10:20 AM
DamonB's Avatar
My rear view became loose at the gimbal itself. The mount was solid but in the summer time the mirror wouldn't hold adjustment and I had to replace it.
Old Mar 18, 2003 | 08:22 PM
overkill's Avatar
so does this mean I just yank the mirror off to get access to the screws???????
Old Mar 18, 2003 | 10:26 PM
fdslave_g's Avatar
A capital FD barbie
When my was loose, the joint was broken so I gotta get a new one, but for emergency case I stuffed in some tissue to make it tight.
Old Mar 19, 2003 | 10:03 AM
Coulthard Fan's Avatar
loose at the ball joint
DamonB - did you try anything else to tighten it up before just replacing it? Mine is loose too when it gets hot. It doesn't bother me to just occasionally readjust it on the street but the track is another story. I've looked at a few websites for larger "racing" rear view mirrors but most seem to just clip onto the existing mirror, which wouldn't solve the problem.
Old Mar 19, 2003 | 10:15 AM
DamonB's Avatar
I tried to take the gimbal apart and somehow tighten or wedge it but I couldn't get the glass to pop out of the mirror to allow access. I was afraid I was going to break the glass anyway so I ended up just buying another mirror from a wrecked car.
Old Mar 19, 2003 | 04:37 PM
93BlackFD's Avatar
built my own engine
mastacow, what happened? send me pics brian@1131.net
(to your car)
mine is loose, thanks guys for posting this
Old Mar 19, 2003 | 04:59 PM
93BlackFD's Avatar
built my own engine
(to your car)
Jutta_J
Mar 25, 2017 11:24 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
