secondary turbo inlet hose rubbing belt?
Old Mar 17, 2003 | 03:01 PM
jayk's Avatar
Is it usual for the hose that goes from the air filter to the secondary turbo to be expanding to the point where it touches the belt? The hose looks like it was designed with a smooth section so that when it expands the ridges don't hit the belt, but I still see a couple places where it looks like the belt has cut into the pipe. As far as I can tell its not all the way through, but I'm guessing this isn't supposed to happen.
Has anybody else experienced this? I've had an issue with a loud screaming sound under full boost over 4.5k, I'm hoping maybe its just the hose expanding and rubbing the belt.
Old Mar 17, 2003 | 07:25 PM
EUROX's Avatar
90s riceboy
Nope, that's not normal. I had the same problem where the belt burned away enough of the hose to open a small hole. All sorts of particulates and crap were getting sucked into that hole, bypassing the filter. Get enough stuff in there and your turbo will sooner or later blow.
Replacing that hose costs about $80 if I remember correctly. I just did it 3 weeks ago.
Old Mar 17, 2003 | 08:31 PM
duboisr's Avatar
Is the front turbo the primary , that intake hose gets rubbed. Adjust the air pump toward the center then tighten the belt with the alternater adjuster
Old Mar 17, 2003 | 08:46 PM
93BlackFD's Avatar
built my own engine
unloosen the clamp where the hose connects to the hardpipe, then rotate the hose out of the way
easy...
Old Mar 17, 2003 | 08:47 PM
jayk's Avatar
I always get the two mixed up, I guess it won't solve my problem. Thanks for the info.
Old Mar 17, 2003 | 08:48 PM
jayk's Avatar
I mean the loud screaming problem, but at least I'll solve the rubbing problem which sounds like it could be serious over time.
Old Mar 17, 2003 | 08:56 PM
RollnDrty's Avatar
I had the same hose rub and wear through. I temporarily used dcut tape to patch it, and just recently installed hard pipes to prevent any damage to the turbines from debri.
streetlegal?
Mar 17, 2022 02:46 PM
Th0m4s
Feb 26, 2019 02:04 AM
