Engine removal tools?
Old Mar 17, 2003 | 08:32 AM
damn hippies
alright...i guess its time to remove my engine and see what i can salvage...can anyone tell me what tools im ganna need to remove the carb and engine?
Stepdaddy
Old Mar 17, 2003 | 12:29 PM
Redwood's Avatar
Find Racing
To take out the engine, just get a hoist. That's it. Unbolt all the connections and yank 'er out.
As for the carb, I imagine it's just sockets? Sorry, I'm FI
Old Mar 17, 2003 | 07:01 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Mostly 14mm sockets.
Uh, a ratchet would help, too...
Old Mar 17, 2003 | 07:05 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
motor mounts = 14mm
the manifold and carb bolts are 12mm
Old Mar 17, 2003 | 08:30 PM
box wrenches 10mm 12mm and 14mm and 14 mm socket and ratchet and some mechanic gloves damn knuckle busters!!!
Old Mar 17, 2003 | 08:55 PM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
Knuckle busters..hahah
Dont forget the 3/4 on the front cover for the main pulley,and the 54mm on the rear for the flywheel,
***** Buster
Old Mar 17, 2003 | 09:00 PM
Felix Wankel's Avatar
Super Newbie
***** Buster
Too bad you don't need those to actually pull the engine...
Old Mar 17, 2003 | 09:16 PM
SoRRoW's Avatar
Re: Engine removal tools?
Stepdaddy
To me this sounds like hes gonna crack it open
Old Mar 17, 2003 | 10:06 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
don't forget to have a pipe of some sort.... for torque purposes..... Some bolts have been there over 20 years... make to lubricate bolts... or it'll snap.... if its too hard, use pipe to use as an extention....
Old Mar 18, 2003 | 12:45 PM
Wankelguy's Avatar
A good cheater pipe helps to save your knuckles, as well.
"All hail the mighty cheater pipe!"
Old Mar 18, 2003 | 12:58 PM
jeremy's Avatar
male stripper
always have a bfh on stand by. thats a given.
Old Mar 18, 2003 | 05:46 PM
brianmcd's Avatar
a chainsaw helps too.
Old Mar 18, 2003 | 06:31 PM
Rotary13B1's Avatar
get a buddy with air tools for everything... sure helps A LOT!.. most useful size on my SE.. 10,12,14,17mm..for the motor~~> cherry picker is a must.. haven't removed one w/o it .. tranny you can just drop it with your knees bracing the bell housing while you loosen the 14mm bolts holding the tranny mount.
Old Mar 18, 2003 | 07:10 PM
MIKE-P-28's Avatar
smoke wrench is the king of all
Old Mar 18, 2003 | 07:11 PM
MIKE-P-28's Avatar
TRUE LOL
Old Apr 5, 2003 | 02:57 PM
85gs's Avatar
Are there particular places on the block to attach a hoist to? With v8s they are easy to see, what about with a rotory? I'll be doing this tomorrow.
Old Apr 5, 2003 | 03:24 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
hoist who needs one..... we got some scafling tossed a pipe across it and hooked up a come-a-long, custom hoist
o and as for where to lift it form. there is a loop in the front that you can hook it to. if yours is not there...... i guess wrap a chain around it several times.
if you dont see the loop i can get a pic or some one can prolly post a pic of what im talking about.
have fun pulling the motor. im pulling 2 next sat. wee.... 1/2 off day. mmmm $150 motors
Old Apr 5, 2003 | 04:27 PM
Keaponlaffen's Avatar
there should be two loops, bolted onto the engine. One in the front, and one in the back. They're pretty easy to see if you're actually looking for them. Otherwise they'll blend in with the rats nest and crap like that.
Old Apr 5, 2003 | 04:29 PM
oppp... one in the back to
Old Apr 5, 2003 | 05:15 PM
85gs's Avatar
Cool, I see the one on front, I'll look closer for the one in the rear. Thanks!!
Th0m4s
Feb 26, 2019 02:04 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
