Need help fast!
Old Mar 17, 2003 | 12:17 AM
Need help fast!
ok so i took off my BAC tonight and i connected the two coolant hoses connected to it and the first time i did it it wasn't tight enought and they ended up seperating and blowing coolant everywhere. so i re connected them alot better and now those are fine but eventhough i put more coolant in and let it bubble as much as i could, the low coolant buzzer just won't go off. i drove the car for about 30 mins and the engine didn't get any warmer than usual, what cna i do to get this damn thing to shut off? thanks
Old Mar 17, 2003 | 12:36 AM
can anyone help me out??? i have to go to work, which is an hour away, in a lil while and i really don't wanna travel an hour with that damn buzzer going off
Old Mar 17, 2003 | 12:41 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
check your water level sensor. I think that is what it is called. You might have disconnected it.
Old Mar 17, 2003 | 12:47 AM
Scott 89t2's Avatar
SOLD THE RX-7!
take the filler cap off. turn the heater on full blast. and let if fully warm up. it'll probbaly take more.
Old Mar 17, 2003 | 12:53 AM
Scott 89t2's Avatar
SOLD THE RX-7!
Old Mar 17, 2003 | 01:08 AM
so i finished checking everything and put the heat on full blast and kept filling the coolant up as it got low and the buzzer finally went off. i took her for a spin and it stayed off for a while and then that hose broke. i just can't win tonight
Old Mar 17, 2003 | 01:11 AM
1987RX7guy's Avatar
how did the hose break? what are you using to put it on the BAC? DOes your cullant light come on or just the buzzer.
A similar thing happpened to me and I thought it was the coolant buzzer but it was the oil buzzer and the oil level sensor was not connected so I cleaned off the crap that was on it and re connected it and never again did I hear the buzzer. did you check to see if your sensor is coneected properly?
Old Mar 17, 2003 | 01:26 AM
well since the BAC is off i just used a littler bigger hose to connect the two ends and used some sealant but that didn't hold, could be i just didn't let it dry enough, so i said **** it and took off the metal pipe they were connected through the bac with and reconnected that. my add coolant light is on and the buzzer is going off. i'm hoping that when i add more coolant this time it'll be fine.
Aramir
Oct 18, 2015 02:39 AM
Devon Murray
Sep 26, 2015 08:15 AM
