Parts needed:tps, maf, bac valve
hey, is there anyone out there who is selling a tps, maf (air flow meter), and a bac valve for a 91 rx7 na.
Also, i just rebuilt my motor and i cant get it to idle. its got good compression, spark, fuel. i can start it up (with a little bit of trouble but it starts) but once it starts up ots runs for a few secs and then stalls out. the only way i can keep it running is if i keep my foot on the gas. does anyone have any idea of whats wrong
? thanks
? thanks
thanks but i already tried to juice up the idle by using the screw and even adjusted the accel. cable back further but it still dont idle. the three things i need will definetly mess with the idling problem right? also i just found out that when i choke off the smog pump nothing happens.( when i used to do that before the rebuild it would stall out almost immediately)now its the same. i keep a pole on the pedal to keep it running.i did a crude tps test, by having it running(at like 2k rpm) and pressed on the the dual tps.nothing happens. does that means its dead? thanks for the replies.
