Microtech Question about Secondary Injector Staging
Old Mar 16, 2003 | 01:54 PM
rx7_turbo2's Avatar
Professor D.P
How does the Microtech stage secondary injectors. Manifold pressure?, RPM based, primary injector duty?
I will be running 1600cc secondaries with 720cc primarys and am wondering about how the staging will take place.
Old Mar 16, 2003 | 02:11 PM
No7Yet's Avatar
You can stage based on TPS signal, RPM, or MAP signal - your choice.
Brandon
Old Mar 17, 2003 | 01:14 PM
rx7_turbo2's Avatar
Professor D.P
Brandon
That's good to hear. Anybody have any experience with what works best? I would imagine in order for the TPS to be effective you would need a full range unit.
We had installed the same setup on a 10th Ann running a Wolf3D V3 and had some trouble interpreting how the secondary injectors were staged, it's good to hear the Microtech does it a bit easier.
Old Mar 17, 2003 | 05:40 PM
10sec rx7's Avatar
On a turbo car you would use MAP, say 00hg or 2psi,
Old Mar 17, 2003 | 06:15 PM
rx7_turbo2's Avatar
Professor D.P
I believe that's how it works on the Haltech
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
