Rims 13''
Old Mar 15, 2003 | 11:53 PM
justrx8's Avatar
Cool Rims 13''
THE FINSH IS COMING OFF AND IT LOOKS **** IS THEY ANY WAY FIX. THIS ARE FACTORY RIM FOR 84 GSL 12A
Old Mar 16, 2003 | 12:20 AM
RotorMotorDriver's Avatar
Seven Is Coming
Strip, repaint, clear coat.
~T.J.
Old Mar 16, 2003 | 12:23 AM
justrx8's Avatar
HOW DO I STRIP THE OLD CLEAR COAT OFF
Old Mar 16, 2003 | 12:33 AM
ioTus's Avatar
'84 5-letter
Piant removerf
Old Mar 16, 2003 | 05:17 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
When I did my wheels I used air craft paint remover,I got it in a 1 gal jug,at Discount Auto parts but this is sold at most large auto stores,
Its very safe for aluminum,
Take the wheel off the car,brush this on the wheel,WEAR GLOVES,cause it will burn let it sit for like 10 mins,get a brillo pad or rough brush and scrap the clear coat or paint off,You migth have to do this in many steps,UNLESS YOU can get a bead blaster,then hit the painted spots,
While your at it,I would polish the wheels out,
Pending on your wheels shape,if they are not damaged,You will have to do a multi step process with sand paper to get out the small pits,then buff to a shine,tape off the area then paint the slots..
It sounds like a lot of work ,but the outcome is nice when done right.
Old Mar 16, 2003 | 11:55 AM
1st to 3rd's Avatar
I couldn't get all the clear coat off with stripper. I ended up sanding it off along with the little ridges then took the sanding marks off with steel wool.
I didn't reclearcoat the wheels because it will yellow and look dull after a short while. I just kept after them with a little Wenol polish. After several years (and winters) they shined like chrome after polishing them.
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
