boost spiking to 15psi
Old Mar 15, 2003 | 03:45 PM
Please read my mod list, but I just got done installing my RB full exhaust setup, and I was driving my car and my boost gauge spiked a couple of times to 15psi, but I quickly let off the gas. My question is, is there anything I can do to avoid this? I know 10-11psi is max on a stock fuel setup ,which is what I have.
Old Mar 15, 2003 | 03:47 PM
dr0x's Avatar
pei > caek
I dont see a mod list anywhere. But port your wastegate.
Old Mar 15, 2003 | 03:49 PM
Yeah I realize that, damnit. Sometimes my mod list shows, and other times it doesn't. weird. Well I'm going to be upgrading to a s5 turbo, well that help?
Old Mar 15, 2003 | 03:53 PM
dr0x's Avatar
pei > caek
Port the wastegate when you get the s5 turbo too.
Old Mar 15, 2003 | 03:54 PM
ok I was planning on it since i'll have it out anyways.
Old Mar 15, 2003 | 03:55 PM
after porting, bout how many psi should I be at?
Old Mar 15, 2003 | 04:02 PM
gsracer's Avatar
EIT
what are the max EGT numbers you are seeing.
With a ported s5 wastegate I would imagine 9 pounds would be possible.
Old Mar 15, 2003 | 10:24 PM
NZConvertible's Avatar
I'm a boost creep...
Read this thread.
Old Mar 16, 2003 | 01:54 AM
rotary>piston's Avatar
with full exhaust, and a stock waste gate, that boost is to be expected. You need to port the wastegate, and get bigger secondaries. at 11 psi you're really pushing those injectors.
Old Mar 16, 2003 | 03:42 AM
Suds7's Avatar
In 3rd or fourth gear it goes to 15psi with turbo connected straight to wastegate (lowest possible setting) this is on a s5 turbo, unported.
Old Mar 16, 2003 | 10:25 AM
Well obviously I need to bring those PSI numbers down to around 9-10. Because I haven't upgraded the fuel system yet.l
13
Jan 9, 2018 11:19 AM
Bauer778
Nov 4, 2015 04:42 PM
Clacor
Sep 11, 2015 08:36 PM
gabescanlon
Sep 5, 2015 12:09 AM
